What do I need to do with 2.6 inch s/c pulley???
Old Feb 22, 2010 | 11:05 AM
Jake SS's Avatar
Talking What do I need to do with 2.6 inch s/c pulley???
I bought a 2.6 inch pulley and I wan to know what all I need to do to the motor to run that pulley?? Can anyone please help me??
Old Feb 22, 2010 | 11:17 AM
zooyrk171's Avatar
60lb injectors,injector harness, smaller belt,heat exchanger and a tune.
Old Feb 22, 2010 | 11:24 AM
Jake SS's Avatar
Alright cool. Thank you. Where would I get a smaller belt? Or could I get a 3 in tensioner pulley??
Old Feb 22, 2010 | 11:30 AM
zooyrk171's Avatar
the tensioner pulley will also work. hit up zzp or ottp theyll have what you need
Old Feb 22, 2010 | 11:35 AM
rallycobalt06's Avatar
i'd highly suggest getting more cooling mods than just a heat exchanger. dual pass w/ option b & meth injection.
Old Feb 22, 2010 | 11:47 AM
Frew's Avatar
x2, heat is a pretty significant problem with a pulley that small, I wouldnt suggest anything smaller then a 2.8 without meth
Old Feb 22, 2010 | 11:51 AM
Supercharged Guy's Avatar
x3 Get all the cooling mods that you can, 2.6 without cooling mods = Boom skeet
Old Feb 22, 2010 | 11:55 AM
i unfortunately know from experience. but hey, you live and you learn.
Old Feb 22, 2010 | 11:59 AM
zooyrk171's Avatar
for some reason i thought he'd said 2.8" so yes deffinately go with as many cooling mods as possible your going to be blowing in alot of heat
Old Feb 22, 2010 | 12:00 PM
Evoly's Avatar
Cooling mods galore!!!! above belt, injectors, tune
Old Feb 22, 2010 | 12:03 PM
Frew's Avatar
exp is the best way to learn, to properly run a 2.6, dual pass, option b, front mount aftercooler. I would also suggest a header, downpipe, cat-back combo, to reduce boost pressure. Fueling 60's for sure, 42's would be too small, IDC would be way over 100% and you dont want your injectors to go static. At this point I believe that the stock intake would be holding you back as well, with a 2.6 you should be flowing somewhere near 41 lbs of air/min through your maf. I would suggest a 3 inch intake along with 3 inch exhaust.
Old Feb 22, 2010 | 12:05 PM
i completely support the above post
Old Feb 22, 2010 | 12:07 PM
Frew's Avatar
tanks bud
Old Feb 23, 2010 | 01:23 AM
87gn06gto07irl's Avatar
If your iat2's are still high you ll need to p&p the s/c and possibly the intake manifold.
Old Feb 23, 2010 | 07:50 AM
Jake SS's Avatar
Thank you everyone for all your help!
That helps me out a lot!
I'll let everyone know how it goes!
Thank you!
Oct 20, 2015 09:56 PM
Builttss
Oct 4, 2015 10:21 AM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
z28addiction
Sep 28, 2015 12:03 AM
