whats my problem.
the car is on methonal... before this happened we had 24 degrees of timing with no kr. after this happened couldnt get it to quit knocking... and we found out why yesterday...
Glad ya figured out the issue OP, Good luck fixing!
Sooo since when can an lsj on 91/93 octane run 22 degrees of timing without knock without meth? I want to see this "factory freak" lol.
edit: are they knocking is the question lol....
Last edited by Zach06CobaltSC; Jun 14, 2009 at 12:57 PM. Reason: Automerged Doublepost
Taking the car to the dealer tomorrow to see what the wanna do.. if they dont want nothing to do with, im going to just put a lifter in it. just so i have the car for super nats this coming weekend. but after the super nats i will probably order cams, valve springs, and have the local machine shop port the exhaust outlets.
pulled valve cover today and.... i broke a lifter in about 3 pieces.. the rocker arm was laying in between the two exhaust rocker arms. ill post pics in a bit. good news out of this...i might be getting the gmr head for nothing... since my brother works at my dealer...
No knock.. Sacrificing a Rich Air Fuel Ratio to run more degrees of timing so.. Its not uncommon at all.
hmmm my car didn't like it even running extremely rich lol, every machine is different though i guess. I needed meth before i could really unleash it.
edit: how does an ingalls set off KR? Mine never did, especially not a 12 degree spike.
Last edited by Zach06CobaltSC; Jun 15, 2009 at 08:02 PM. Reason: Automerged Doublepost
me and boostedyards86 were logging one day with hp tuners, and at like partial throttle i was getting like in upwards of 12 degrees of kr, so we ran back to his house took off the damper, got on the highway to tune and threw 20 degrees of timing at it without meth, long story about how we found out that it was causing the knock sensor to go off
cam is fine.. it was scored into it... there was now burrs sticking out... the lobe the was scored didnt even mark that rocker arm. and the rocker the was just chilling in the motor was fine no scratches chips or anything on it. only took about 45min to fix.
and yes ill be at the super nats for sure... its like 5 minutes from me...lol
TheSandMan
Sep 20, 2015 06:02 AM
