whats this part do...?
Old Dec 4, 2005 | 04:02 PM
Doc's Avatar
Doc
Ok, this may have been covered...but I'm posting this anyway...
I took some pics of my engine compartment and I noticed on the back of the supercharger there is an allen screw. What does this control...??
This is an orientation pic to put you in the right area
I know with my old R/T that you could control the throttle kickdown by adjusting the amount of space there was near the throttle body.
I wonder if this is something similar or maybe a thing to control vacuum.....
Old Dec 4, 2005 | 04:29 PM
lildudeus's Avatar
Lightbulb
i believe that this is your "Blow off" valve to prevent the supercharge from creating a negative boost to the engine wich is very bad but i might be wrong
Old Dec 4, 2005 | 04:34 PM
Doc's Avatar
Doc
I know we are either under vacuum or boost....I think I heard that we were under vacuum 95% of the time and boost the rest.
There is a plunger of some sort, and that allen screw controls it somehow....I aint messing with it until I get a 'techie' point of view...
Jmc007's Avatar
https://www.cobaltss.net/forums/show...9&page=2&pp=20
See posts #34, 35 ...
Old Dec 4, 2005 | 05:01 PM
Doc's Avatar
Doc
Thanks... seems you've had this on your mind before
Let me get this straight first.
The position of that screw dictates the opening or closing of the actuator, which dictates boost/vacuum pressure.
Has there been a 'benchmark' position made for these screws..? or is it mainly up to personal preference.?
I see that if 12lbs of boost is made it wont make more. I am real close to 12.5lbs now...
all in all, its great info
thanks again
Old Dec 4, 2005 | 07:04 PM
zinner's Avatar
Moderator Alumni
That is the bypass valve. The screw adjusts the point where the valve closes. Changing it might prevent the butterfly valve from closing correctly. If that happens you lose boost.
Old Dec 5, 2005 | 11:00 AM
codyss's Avatar
Doesn't the valve inside the S/C have a stop also? Doesn't it sit inside of a machined plate?
SO it can't really go to far closed can it?
Old Dec 5, 2005 | 11:11 AM
R33P3R007's Avatar
360 L337 User
is there a way to find the maximum boost point. or is it set close enough at the factory. Could this be the reason many people are not getting 12.5psi
Oct 20, 2015 09:56 PM
HEATON
Oct 16, 2015 07:21 PM
justinchinn
Oct 2, 2015 12:18 PM
dieGone
Oct 1, 2015 06:27 PM
metroplex
Sep 27, 2015 07:48 AM
