Whats your boost?
Old May 9, 2006 | 10:23 PM
titancrash's Avatar
Whats your boost?
Yhis may sound strsnge but my boost guage reads way higher than it should. Iknowe they should be getting around 12.5 psi, but at redline mine reads 17.5,I only have an injen intake. Have any of you had any guage malfunctioning problems?
Old May 9, 2006 | 10:35 PM
l Sh1ft l's Avatar
Uh oh..
l Sh1ft l's Avatar
Somebody else was having this problem.. Unfortunately it led to his many malfunctions haha.
Old May 10, 2006 | 01:09 AM
knatsabooh's Avatar
mine runs toiaround 80 KPA. don't know what that converts to in P.S.I. tho, and i'm too tired and lazy to find out right now.
Old May 10, 2006 | 01:14 AM
Toronto SS's Avatar
80ish is around 12psi
Old May 10, 2006 | 01:17 AM
italstalnprd86's Avatar
sounds like your cats messed up man..... im running 15psi with boost bypass and a 3 inch pully
knatsabooh's Avatar
cool... ya thats about right then. I had seen others with gauges around that also, but they were asking if that was normal too so i wasn't completely sure... thanks.
Old May 10, 2006 | 01:19 AM
fastSS06's Avatar
yeah...something is definitley messed up.....I'm running just shy of 17psi, with intake, 2.9, and boost bypass mod.
Old May 10, 2006 | 01:21 AM
cobss187's Avatar
go out and get urself a new cat
Old May 10, 2006 | 01:26 AM
knatsabooh's Avatar
stock pulley i'm fine around 12 - 13 tho ... 80 - 85 KPA ...
Old May 10, 2006 | 03:39 AM
snarkee's Avatar
stock with under 1000km on the car 90 kpa
Old May 10, 2006 | 05:21 AM
Badmunky's Avatar
I ran 12.5psi stock and am at 16psi with GM stage 2.
If your pushing that much boost stock then ether your catt is on its way out or that gauge is broken.
Get in and have the dealer check it out ASAP! But take the intake off and go back to stock first so they dont give you crap about it.
Later
Old May 10, 2006 | 05:51 AM
titancrash's Avatar
I guess i'll drop it off at the dealer and see what they say.
Old May 10, 2006 | 07:59 PM
titancrash's Avatar
Did i mention my car only has 880 miles on it. Is it possible for the cat to go out that fast. And what could the consequences be if I don't get it fixed soon?
Old May 10, 2006 | 10:50 PM
Fast Freddy's Avatar
intense stage 3, 18 lbs.
Old May 10, 2006 | 10:52 PM
patathSS's Avatar
19psi
Old May 10, 2006 | 11:08 PM
ReMz's Avatar
yeah... thats not right man. 16psi on a stock engine with low milage..... get that to the dealer.
i kno i only run 10.5-11 (11 if im lucky), but that is because i am at high altitude. the altitude is only making a negative 1 to 1.5lb difference tho. so running nearly 4psi higher doesnt sound good.
or maybe you have a super super sport cobalt =P
Old May 11, 2006 | 12:49 PM
TexasPhil's Avatar
definately sounds like you have a clogged cat
Old May 11, 2006 | 01:01 PM
BLKSS's Avatar
115kpa
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
717ssbalt
Oct 2, 2015 04:01 PM
