When does your clutch grab?
Old Mar 21, 2007 | 05:34 PM
Psykostevo's Avatar
Originally Posted by DoubleLP
Takes some practice...but done right it does not hurt the car at all.
X2!
Old Mar 21, 2007 | 05:39 PM
OniMirage's Avatar
engages and disengages in the same spot since i bought it as others have said
Old Mar 21, 2007 | 06:06 PM
MaJ's Avatar
MaJ
Mine seems to grab somewhere around the middle. It has been this way since I bought the car.
Old Mar 21, 2007 | 06:14 PM
chevysssc's Avatar
3 /4 to top watch that wheel hop trans case will crack and leak fluid on the clutch gm knows the problem but wont warrnty it
Old Mar 21, 2007 | 06:38 PM
DoubleLP's Avatar
I could see why they would not warranty because you are not supposed to have wheel hop or produce wheel hop with the car.
It would be no different if you lost the clutch say after 5000 miles because you kept dumping the clutch.
Just my opinion.
Old Mar 21, 2007 | 06:42 PM
mysweetSS's Avatar
mine grabs almost on the top, just like the day i bought it from the dealership... AND I HATE IT!!!!
Old Mar 21, 2007 | 07:06 PM
SSdan's Avatar
Doesnt bother me that it lets out near the top, but it bothers me that the pedal travel is so long when it lets out so close to the top.
Old Mar 21, 2007 | 07:30 PM
Psykostevo's Avatar
Just my opinion.
On the contrary, there are a few member's who have been able to get the clutch replaced under warranty. My understanding is that there has to be no other signs of abuse, and you have to be a dick about it..............the later probably helps.
Old Mar 21, 2007 | 09:52 PM
PolishPauL's Avatar
I always have downshifted since I started driving and it definitely is a plus in the s**t winter weather as well since you are using the engine to help you slow down too.
How can it hurt the car? When you downshift without givin a some gas and the car jerks back? Is that bad?
Old Mar 22, 2007 | 10:14 AM
aj_92rs's Avatar
Another FYI,
Some people have a bad habit if slightly resting their left foot on the clutch pedal while driving in city traffic. It doesn't necessarily wear out your clutch faster, but as Psykostevo pointed out, it will slip just a wee bit and increase the glazing effect.
Make sure your clutch foot is off the pedal when you're not using it to change gears.
Another habit a lot of people have, and I know it's bad on RWD transmissions, is leaving your hand resting on the shifter while driving. This puts excess strain on the bushings and syncros. I know this is difficult to avoid with the Cobalt because the buttheads at GM didn't put an armrest in the manual trans cars, but try to avoid it as much as possible.
Let the clutch out gradually as if you were upshifting. This will slowly bring the RPMs up to the rotating speed of the transmission.
And yes, any jerking is bad, unless you're at home, alone.
Old Mar 22, 2007 | 02:16 PM
  #36
Psykostevo's Avatar
Lol, yeah, don't get caught with a JWD, That would be bad.
I fixed GM's problem in my car! Get your lean on!
Old Mar 22, 2007 | 03:10 PM
  #37
DoubleLP's Avatar
As aj_92rs said, just let the clutch out SLOWLY when you are downshifting, no pushing the gas at the same time. It will grab and the RPM's will come up gently.
Best way I learned was downshifting from 3rd to 2nd. You will do that a lot anyways, and once you have mastered it you can do that with any downshift. Just DONT do the 2nd to 1st downshift. It is really harsh and because of the gearing you will be thrashed around somewhat.
Old Mar 22, 2007 | 06:32 PM
  #38
OniMirage's Avatar
i usually put my hand on my gf's thigh to rest my hand when not using the shifter so I avoid resting it on the shifter. Agree with slowly engaging the clutch (downshifting) to slow you down. I know some people use rev matching to accomplish the same thing but im not sure why cus if you rev to high you don't get any slowing benefit and if your too low you get jerked around when it does engage. Just engage slowly and your good
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
