Why dont ecotecs perform better with cams
Old Jan 23, 2015 | 11:46 AM
  #76
mrbelvedere's Avatar
Originally Posted by alerosaint
oh ok. But you can get the same duration and lift as a zzp stage whatever cam but would yield XX more hp. So your best guess ~50-70whp gain =)?? I guess what im wondering, theoretically can this process yield huge gains for ecotecs on cams?
why would you want to run a hyd profile on a solid lobe and as alan said it would be a guess my blanks should be at the grinder
Old Jan 23, 2015 | 12:06 PM
  #77
alerosaint's Avatar
idk..lol Im not too savvy on internal stuff, trying to learn, I was just asking for a good general guess for comparison sake out of curiosity. Your guess would be better than most.
my bad I meant can you instead of you can on my earlier post. was a question
Old Jan 23, 2015 | 12:20 PM
  #78
Spawne32's Avatar
a solid cam is going to have a different lobe compared to a hydraulic cam its like comparing oranges and meatloaf to one another
How exactly are they different, thats my big question? Is the material different? Is the ramp angle changed? etc
Old Jan 23, 2015 | 01:05 PM
  #79
LNFTX's Avatar
At what point does this become an issue?
Is it an issue with stock cams/springs/lifters or s1 or s2. I think I now understand the problem and vaguely understand the solution but cant figure out if its always an issue with the ecotec and the cams/springs make it worse or if a certain set-up causes the issue
Old Jan 23, 2015 | 03:39 PM
  #80
any boost over 18psi will start collapsing the lash adjusters stiffer valve springs will lower the thresh hold for the collapsing point bigger cams with an increased rate of lift will also affect things
Old Jan 23, 2015 | 03:42 PM
  #81
Viperoni's Avatar
To all the people asking questions between Hydraulic and Solid lifters:
COMP CamsŽ - Lifter Technical Reference
As for power gains, it's tough to say, I'm not sure there's been anybody that's actually run a solid lifter..... but having said that, upgrading from cams normally make a pretty decent difference on worked over motors in general (IE: ported head, bigger SC than stock, etc etc).
Old Jan 23, 2015 | 03:45 PM
  #82
Hockeyman's Avatar
can't wait for my setup with solids!! Good read John.
Old Jan 23, 2015 | 04:34 PM
  #83
the race teams run them and they are used in other platforms with no problems
Old Jan 23, 2015 | 05:15 PM
  #84
Viperoni's Avatar
Oh yeah solid lifters aren't a new idea by any means.
Didn't the Honda B series motors use solid lifters (I know they had to get lash adjusted every so often and had lifter tick issues)....
Old Jan 23, 2015 | 06:33 PM
  #85
armcclure's Avatar
That's one of the nice things about our head; once assembled, the only way it would ever need adjustment would be if something is mechanically failing. Such as valve seat sinking, stem mushrooming, rocker wearing out, etc. there is simply nothing to move.
Old Jan 23, 2015 | 06:45 PM
  #86
Tsbbzm's Avatar
Jedi Master
Good stuff.
Old Jan 26, 2015 | 09:13 AM
  #87
SSfamilywagon's Avatar
Nice read and glad something has been figured out as to the lack luster gains from our current builds and cams selection.
This makes me glad I'm still on the stock head and waited patiently to build a nice ported head with the right internals in it.
So solids and cams with ported head and bigger exhaust valves would be a nice combo to use.
Old Jan 28, 2015 | 12:47 PM
  #88
Shanman's Avatar
Well crap guess I fit into the, 'My lash adjusters are gonna collapse on me soon bus...'
I get buying custom ground cams, but where do they offer solids?
Subd
Old Jan 28, 2015 | 01:13 PM
  #89
they already are im working on solid cams
Old Feb 4, 2015 | 12:15 AM
  #90
Oh yeah?
Old Feb 19, 2015 | 10:41 PM
  #91
Any update?
Old Feb 20, 2015 | 08:17 AM
  #92
yea they are getting a profile together stuff takes time
Old May 28, 2015 | 10:05 AM
  #93
Viperoni's Avatar
Mr.B, what you're doing isn't related to JapEatrs Gates solid lifter stuff, is it?
Old Jun 1, 2015 | 01:16 PM
  #94
JapEatr's Avatar
South Central *********
it is... kinda im going to be running Bates, but John is using the Jesel lifters
Old Jun 1, 2015 | 04:01 PM
  #95
Viperoni's Avatar
Poorly worded question on my part but you answered it - Mr.B's using Jesel parts and you're using Bates, but they're both solid lifters.
Can't wait to see the results!
Old Jun 1, 2015 | 06:26 PM
  #96
JapEatr's Avatar
Jesel are adjustable
Old Jun 1, 2015 | 07:03 PM
  #97
What kinda modifications have you needed to make to run the solid lifters and cams?
Old Jun 1, 2015 | 07:53 PM
  #98
JapEatr's Avatar
Custom ground cams for solid ramp, valve job, each lifter cut to the exact lash
Old Jun 1, 2015 | 09:35 PM
  #99
How often are you expecting to have to adjust the valvetrain? Im assuming this is a big no no for daily cars?
Old Jun 1, 2015 | 10:47 PM
  #100
JapEatr's Avatar
Only need to change lifters if I change cams
