Why dont ecotecs perform better with cams
Old Jun 2, 2015 | 02:10 AM
  #101
So theres no lash adjustment needed? I guess because the valvetrain is so short.
Old Jun 2, 2015 | 08:44 AM
  #102
JapEatr's Avatar
South Central *********
There's nothing you can adjust on the bates lifters, once cut thats the lash, these heads cannot be shimmed
Ask John about his harley davidson pushrod haha
Old Jun 2, 2015 | 10:23 PM
  #103
SSfamilywagon's Avatar
Well that's good to know. I've been waiting to build a head until this whole solid cam set up was finalized and working right. I was never happy reading the results from the hyd cams out now. Good to see you guys getting it all done.
Old Jun 2, 2015 | 10:42 PM
  #104
I second that i really appreciate you guus being pioneers of the likes for get to ng this kinda stuff figured out.
Old Jun 2, 2015 | 11:04 PM
  #105
JapEatr's Avatar
To be honest its all Belvedere im just helping R&D
Old Jun 2, 2015 | 11:15 PM
  #106
Im definitely down to get some solid lifter cams if the results are good. Where can i get le5 blanks?
Old Jun 2, 2015 | 11:18 PM
  #107
JapEatr's Avatar
Not sure try CED
Old Jun 3, 2015 | 09:46 PM
  #108
20Tsaabsteve's Avatar
You said in the original post, all lifter generations. Have you seen the newest ones that are also used in the HFV6 and the newest Ecotec's? They cannot be disassembled it appears, and the tip is necked down (I can post pictures if needed). I suppose they are having the same problems as well? If it is strictly on lifter size, then I could see that. It seems like the head could be machined to accept a larger lifter if need be (like the Honda lifter if it is better). I cannot see a lot of people going solid due to cost. What about long term wear issues also? Not trying to hate, the information given is great. I am just trying to approach it from a practical angle of keeping the hydraulic setup and optimizing it as much as possible. Will continue to follow this thread and maybe get a junk Ecotec head to do some testing on.
Old Jun 3, 2015 | 10:31 PM
  #109
JapEatr's Avatar
Has nothing to do with hydraulic lifter length, it has to do with them collapse under high cylinder pressure and lift
Old Jun 4, 2015 | 01:03 AM
  #110
soundjunky's Avatar
Originally Posted by 20Tsaabsteve
You said in the original post, all lifter generations. Have you seen the newest ones that are also used in the HFV6 and the newest Ecotec's? They cannot be disassembled it appears, and the tip is necked down (I can post pictures if needed). I suppose they are having the same problems as well? ...
/\ /\ On possibly a related note;
I recently was told that the OEM lifter part number has been superseded - maybe this new design lifter is to be used on them all?
Old Jun 4, 2015 | 08:20 AM
  #111
mrbelvedere's Avatar
the first three generations of lifters your not supposed to be able to take apart either so we cut them open but post pics of the gen 4 lash adjuster
Old Jun 4, 2015 | 05:19 PM
  #112
I was talking diameter, not length. More surface area against the oil, less susceptible to collapsing.
I will post pics too, you also want gut pictures?
Old Jun 4, 2015 | 05:22 PM
  #113
The part number I have is the same lifter that fits the LF3, LTG, etc. The old style has a crimp ring, this new style must have an internal snap ring.
Old Jun 5, 2015 | 03:30 PM
  #114
Here are pictures of the latest generation lifters (gen 4?)
If you look closely you can see the oil feed hole is positioned slightly higher and is a tad bigger, while the relief/follower oil feed hole is definitely smaller. You can also see the necked down portion I described earlier. Can cut it open if it's wanted.
Old Jun 5, 2015 | 04:19 PM
  #115
JapEatr's Avatar
Can you get an overall length
Old Jun 5, 2015 | 05:31 PM
  #116
Well that's definitely different
Old Jun 5, 2015 | 09:30 PM
  #117
It seems to be the same length as the others but I can measure it with a caliper gauge tomorrow if you want.
Old Jun 12, 2015 | 10:11 AM
  #118
armcclure's Avatar
Every generation is within a couple thousandths. I already went through all of this
Old Jun 16, 2015 | 09:59 AM
  #119
dsm on left ecotec on right do i need to say more
Old Jun 16, 2015 | 12:58 PM
  #120
JapEatr's Avatar
Well those wont fit haha
Old Jun 16, 2015 | 01:23 PM
  #121
LNFTX's Avatar
stupid question that shows my level of understanding
what would it take to run a larger lifter like that?
completely custom machined head and matching valvetrain?
Old Jun 16, 2015 | 01:44 PM
  #122
07blackg5's Avatar
Slobodan Milošević
drilling out a hole that bit would take out a quarter of our head
Old Jun 17, 2015 | 07:06 PM
  #123
Do you know how big the Nissan lifters are for the SR20det?
Old Jun 21, 2015 | 05:53 PM
  #124
never seen any of the nissan junk
Old Jun 21, 2015 | 06:09 PM
  #125
TStone's Avatar
Hard to tell just by google pics, but the sr20det ones look "fatter" or "wider"
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
goaliemo
Sep 28, 2015 01:37 PM
