Why is there a thread on changing your SC oil, is it not oil for life?
Old Jun 22, 2010 | 12:20 PM
EcoTecDriver's Avatar
I read through GM that the oil should not be changed/messed with on the m62?
is this not true?
Old Jun 22, 2010 | 12:46 PM
hungryhip-ccp's Avatar
yes it is considered a "sealed unit" which is good for 100k+ miles. But alot of people are running smaller pulleys than stock which are spinning the **** out of the blowers. So some feel it is good idea to change it.
I would just wait till the coupler gets noisey and change both at the same time.
I have changed mine before, and it was not needed. So i dont recommend it.
Old Jun 22, 2010 | 12:53 PM
thanks!
Old Jun 22, 2010 | 01:09 PM
cobaltguy889's Avatar
I would reccommend changing it every 25k miles. You can order oil through zzp for like 10 bucks, and it takes 15 minutes to change. Take out the plug, drain, refill.
Old Jun 22, 2010 | 01:16 PM
^seems excessive
Old Jun 22, 2010 | 01:22 PM
its really not that excessive unless you put a ton of miles on your car. I usually put 25k on over a year and a half.
Old Jun 22, 2010 | 01:28 PM
I have put 28k on my car since 07, original owner too lol
Old Jun 22, 2010 | 03:06 PM
so whats once every 2+ years?
Old Jun 22, 2010 | 03:38 PM
mrbelvedere's Avatar
dude that is retarded its not needed till 100k or longer even if you run a 2.5 pully
Old Jun 22, 2010 | 03:43 PM
Its not retarted. Ask ebristol. He changed his with 20k+ miles on it, ask him what it looked like. I was there. After seeing his, I changed mine.
Old Jun 22, 2010 | 05:28 PM
lol its supposed to look like that
Old Jun 22, 2010 | 06:17 PM
hey, do what you guys think is right for your cars. I'm just shooting out a reccomendation.
Old Jun 22, 2010 | 08:25 PM
Nighthawk243's Avatar
If you're stock or GM Stage 2, you don't really need to change it unless you service the blower (Coupler replacement...etc).
If you're using a small pulley, you should do a periodic change depending on how much you push the car.
Old Jun 22, 2010 | 08:34 PM
Redefined1's Avatar
if youre overspinning the blower i assume the oil is getting very hot and some of its properties will be lost alot faster that way. i dont know exactly when you should change it but 25k doesnt sound bad to me.
06MetallicBalt
Jul 20, 2025 08:47 PM
brandon04
Oct 21, 2015 07:04 AM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
roth
Sep 26, 2015 12:16 PM
