Wicked's car is down...... Troubleshooting assistance needed
Old Jun 12, 2011 | 12:57 PM
WickedSS2005's Avatar
Well, I get in the car to head to work yesterday and get greeted with a CEL. Usually never an issue as I can just check it when I get home. I live 5 min from my employer. Not the case this time. A block from home I get "ENG PWR REDUCED" and limp it back home.
Checked the codes finally today after working a double shift yesterday and received these:
[PCM] P2134 - Throttle/Pedal Position Seneor/Switch A/B Voltage Correlation
[PCM] P2101 - Throttle Actuator Control Motor Circuit Range/Performance
[PCM] P1681 - Driver 5 Line 1
Now there was never a Driver 5 made for the PalyStation systems so it's not a gaming related issue...
My assumption is throttle body related. Either the plug is corroded/damaged somehow, throttle body is toast, or an electrical problem. Praying it's not a gremlin.
Anyone combated these codes before? I have to head out for errands and my roommates birthday today or I'd go play under the hood. Car has been fine for a year and 26 days (headgasket last May). Go figure this happens a couple days after my birthday last Tuesday
Old Jun 12, 2011 | 01:06 PM
383_Stroker's Avatar
My car did that exactly, i replaced the TB and solved the issue..
FWIW once the car warmed up i could clear the codes with HPT and drive on..
Also, if you remember my ghetto ground speaker wire mod on my throttle body..... that's why it was there
Old Jun 12, 2011 | 01:31 PM
Also, check your logs.. my throttle position looked like an ekg when holding steady throttle
Old Jun 12, 2011 | 01:57 PM
lsjion's Avatar
sounds like it needs a gas pedal position sensor, I have a throttle body you can use to try, but I highly doubt that's it
Old Jun 12, 2011 | 04:58 PM
Tstonee's Avatar
Got 2 days to fix it bc I wanna hear/see it run!
Old Jun 13, 2011 | 01:59 AM
Well, it'll prob be 2-wheelin it for a couple days. You can hear the bike run It's sexier
Old Jun 13, 2011 | 02:04 AM
Tstonee's Avatar
Idk now )': aha.. got some problems of my own. Hope all goes well for ya !
Old Jun 13, 2011 | 11:04 AM
Wish I had more ideas for ya. Transmissions aren't my thing. Good luck with it man
GaryGibblez
Jan 14, 2020 10:35 AM
How to Guide
57
Oct 15, 2015 11:56 AM
OrngBalt
Sep 16, 2015 07:45 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
SS_2009_TC
Sep 4, 2015 10:48 AM
