Will my 36 lbs injectors fit>?
South Central *********
i recently acquired a set of 6 36lbs injectors from a GTP
what size are the stock ones and will these fit?
the computer would stilll need the reflash but that saves me some dough if these work
Originally Posted by 97cavie24ls
stock is 35-36lb injectors
also the gtp's have a different plug
does anyone have any proof of this? Thats a big injector to be maxing out with a 2.0 w/ small supercharger. GTPs dont max out their injectors (36#) until they get around a 2.9 pulley but thats with a m90 and 3.8L engine. I would highly doubt the SS/RL have 36# injectors from the factory. And if they did, they would not be maxing them out with just a pulley change.
ive got 30lb in my cav with the m45 gm s/c , and they are too small
ive got a friend in VA , that builds the injecotrs , they are 35-36 lb injectors
im putting the 2.0 s/c injecotrs on my cav , so i can drop the pressure some , since ive got it maxed at 60psi , and im still lean under boost , low 13's at 6-7psi
alot of the gtp guys i know jump to 42lb injectors , alot sooner than a 2.9 pulley
The 3800 supercharged is 240 HP isn't it and 6 injectors? We are easily 215 HP and 4 injectors
I don't think it's a leap that we have 36# injectors in that case. I don't know much about them tho.
Stock GTP's injectors are probably flowing less than the Cobalt SS one, since stock for stock both car produce roughly the same BHP and the Cobalt SS do it with only 4 injectors.
I don't think you should do that, also the connector are probably different.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
