Will the P0171 code affect performance?
Old Mar 14, 2012 | 04:02 PM
blackjack232's Avatar
will getting the code after the zzp intake affect performance?
Old Mar 14, 2012 | 04:05 PM
willie_panic's Avatar
I would think yes since that is a lean condition and if you aren't getting enough fuel in with the air then you aren't getting the full benefit.
Old Mar 14, 2012 | 04:54 PM
how might i be able to change the value for this mod? do i NEED to get an HP tuners kit?
Old Mar 14, 2012 | 04:56 PM
07LSJ's Avatar
what?
Old Mar 15, 2012 | 10:19 AM
You need to find out what your AFR is and go from there. I am not a tuner and I won't claim to be. There are several tuners on here who I am sure would be able to help you with your car. Have you installed the part already? and Did you get the code after the install or before?
Old Mar 15, 2012 | 11:38 AM
boosted05ss's Avatar
[QUOTE=blackjack232;6394700]will getting the code after the zzp intake affect performance?[/QU
LSJ's tend to throw the lean code when its colder out. As spring and summer comes your car naturally will start to run richer. My 06 did it every fall before i parked it for winter, tuning will fix but if your not looking to go that way jus yet wait till it gets above 50 and clear the code and see.
Old Mar 15, 2012 | 11:22 PM
so that code has nothing to actually do with the MAF? more with the IAT?
Old Mar 16, 2012 | 10:00 AM
the maf is off because of the greater volume of air passing by it. When its colder air is less dense and actually the maf just cant adjust to that amount.
Old Mar 16, 2012 | 10:40 AM
06cobalt racer's Avatar
Originally Posted by boosted05ss
the maf is off because of the greater volume of air passing by it. When its colder air is MORE DENSE and actually the maf just cant adjust to that amount.
fixed it
mrbelvedere's Avatar
air is more dense when it is cold out
Old Mar 16, 2012 | 10:46 AM
user 72239's Avatar
I used to get p0171 with my zzp 3in intake on my LSJ. The "Fix" is to tune the car for the intake, however I ran it for 4 months with no problems. I got the code twice in that time, and just cleared it. However, I traded my LSJ in but was planning on tuning it.
turbochargedss2012
Sep 20, 2023 12:17 PM
Oct 13, 2015 09:32 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
