wiring in dash dvd player
Hey guys I need help I have a pioneer in dash DVD player and I need to know where the two wires go for the park brake wire and reverse wire go thanks
there is a way to wire up a basic relay to make it so you can watch movies while the brake is off...hold on lemme find it
something like this...
they say that you should use a relay because I guess the head unit needs to see a change of voltage/ground and if it doesn't it won't work. So by installing this relay it will get a that quick switch soon as you turn on the car...
just run the wire to a switch, then run another wire from the switch to a ground, this is what i did with my pioneer. Then when you wanna watch dvd's you just flip the switch and bam.
