wiring in dash dvd player
Old 02-12-2011, 05:39 PM
goeckeritz123's Avatar
Hey guys I need help I have a pioneer in dash DVD player and I need to know where the two wires go for the park brake wire and reverse wire go thanks
Old 02-12-2011, 05:42 PM
Old 02-12-2011, 06:24 PM
troyss's Avatar
To a ground so it can play dvd
Old 02-12-2011, 06:38 PM
How can I hook it up so the park break dose not have to be on
Old 02-12-2011, 06:43 PM
troyss's Avatar
Usually you just hook it up to the ground wire and then you can play it withOut brake on
Old 02-12-2011, 06:53 PM
It only wants to play when the cars off I have it grounded on the sunroof fuse
Old 02-12-2011, 07:00 PM
troyss's Avatar
The fuse will be a positive not a ground.. Try to take the brake wire and touch it to the black wire on your radio..
Old 02-12-2011, 07:25 PM
Ill give that a try
Old 02-12-2011, 07:50 PM
Omnigear's Avatar
a hammer for posting on the wrong section
Old 02-12-2011, 08:35 PM
mrbelvedere's Avatar
try searching the audio section
Old 02-12-2011, 11:48 PM
iboost's Avatar
there is a way to wire up a basic relay to make it so you can watch movies while the brake is off...hold on lemme find it
something like this...
they say that you should use a relay because I guess the head unit needs to see a change of voltage/ground and if it doesn't it won't work. So by installing this relay it will get a that quick switch soon as you turn on the car...
Old 02-13-2011, 12:47 PM
MrSlickSter06SS's Avatar
I just grounded my Kenwood, and dvd worked like a charm... Good luck..
Old 02-13-2011, 01:32 PM
ssforlife's Avatar
audio section..........
Old 02-13-2011, 01:36 PM
reaper89's Avatar
just run the wire to a switch, then run another wire from the switch to a ground, this is what i did with my pioneer. Then when you wanna watch dvd's you just flip the switch and bam.
Tupp
2.2L LAP Performance Tech
01-02-2016 12:04 PM
dennis69
10-20-2015 07:39 AM
ernnyyes
10-02-2015 05:16 PM
c_m_shooter
09-27-2015 04:40 PM
jmelton327
09-26-2015 10:04 PM
Quick Reply: wiring in dash dvd player
