ZZP 2.4 Max Power Testing
Old Jul 5, 2011 | 02:01 PM
  #76
G11's Avatar
G11
awesome! cuz thats what im lookin for! hopefully by nov. or dec. i will have the money for the built trans and motor
Old Jul 5, 2011 | 04:17 PM
  #77
Matt M's Avatar
450 could be done on the TVS with cams, ported head, and E85. Tim's setup only ran about 12-13psi boost if I remember right.
Old Jul 5, 2011 | 04:53 PM
  #78
Boosted05's Avatar
Will ZZP be attending the GM Performance day at Milan by chance, if not do y'all want to sponsor a car for the bracket races
Old Jul 5, 2011 | 04:59 PM
  #79
mrbelvedere's Avatar
i think more then 450 could be had come zzp do it tvs a stroker
Old Jul 5, 2011 | 05:51 PM
  #80
Tennpenn83's Avatar
Originally Posted by ebristol
If they can get 400whp out of an M62 on that setup, 500whp out of a TVS would not be out of the question.
And remember that was on a relatively large pulley with low boost. Imagine a TVS with the same pulley right around 450. Maybe higher with smaller pulley.
Old Jul 5, 2011 | 05:56 PM
  #81
tim had a 2.6 on the m62
Old Jul 5, 2011 | 06:59 PM
  #82
hungryhip-ccp's Avatar
I thought it was a 2.7 pulley with ATI overdrive crank damper.
Old Jul 5, 2011 | 09:18 PM
  #83
Tennpenn83's Avatar
I stand corrected, 2.7 M62 with ATI dampener. Still, that pulley produces in excess of 23+ psi boost on a ported head, full 3" combo, so with the increased displacement I could see around 5psi higher than the M62. I'd like to see what it can do.
Old Jul 5, 2011 | 10:37 PM
  #84
elecblue06's Avatar
? i must be misunderstanding you because increasing displacement drops boost
Old Jul 5, 2011 | 10:39 PM
  #85
when zzp did max power testing im pretty sure he ran a 2.6 and i know he has used a 2.5 at the track and he said he was only seeing between 12 and 15 lbs on the stroker
Old Jul 5, 2011 | 10:41 PM
  #86
Matt M's Avatar
When are they having it?
Old Jul 5, 2011 | 10:46 PM
  #87
Tennpenn83's Avatar
Guess I didn't word it good
The TVS will produce about 30% more psi on the same size pulley'd M62
M62 3.1" ~ 14psi
TVS 3.1" ~ 19psi
So if the 400whp M62 build had a 2.7" pulley on it and with the increased displacement made 12-13 psi boost, then it's fair to say that you'd see probably 17-18 psi with the TVS on a 2.7"
Not sure how much that equates to in whp, but I'd love to see it.
Old Jul 5, 2011 | 10:51 PM
  #88
LS6Rally's Avatar
Sub'd for this one, you guys are the ****
Old Jul 6, 2011 | 01:33 AM
  #89
1fastSSBalt's Avatar
If you guys end up coming to Milan drag way I want to know when as well. I don't live to far from there.
Old Jul 6, 2011 | 08:13 AM
  #90
Boosted05's Avatar
July 30th, they have bracket racing and a car show. I'm planning on doing both, Since I got the car running really good right now. ZZP power ftw.
Old Jul 7, 2011 | 01:00 PM
  #91
G11's Avatar
G11
well what would you think i would get with the stroker and all the bolt ons that i have...and with the tvs on a 2.6 right now im only at 20 psi if im lucky haha
Old Jul 7, 2011 | 02:25 PM
  #92
quit being a vag go buy it and tell us and your making more then 20 on a 2.6
64mm / 2.5" ~ 27.5 psi
70mm / 2.75" ~ 25 psi
75mm / 2.95" ~ 22.5 psi
80mm / 3.15" ~ 20 psi
85mm / 3.35" ~ 17.5 psi
89mm / 3.5" ~15psi
Per Area47, note this is with a higher redline w/ upgrade valvetrain: as a slight correction to the psi reference.
if you spin the motor high enough a 3.1 pulley will make 23psi. a 2.9 will make 25, and a 2.75 will make 26.5. 99% of the tvs owners will not spin their engines to 7900 to see this. i personally have seen 27psi out of the 2.75 ring
Old Jul 7, 2011 | 02:32 PM
  #93
G11's Avatar
G11
well im just going off of what interceptor says and that is at 7500 rpm 20.2 to be exact
i have to save up more to get all of this stuff first haha! it wouldn't be till oct at the very earliest.
Old Jul 8, 2011 | 02:20 AM
  #94
I will definitely be there, probably won't race since I have never been down the track....but ZZP you should come and install injectors/pulley and hub and my meth and tune me =D I'll rock some ZZP logos/decals =D
Old Jul 8, 2011 | 12:02 PM
  #95
2010redrocket's Avatar
Did you guys stop power testing on this setup??? Just have not seen any updates recently.
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
