ZZP 3" Intake
Old Feb 11, 2009 | 05:08 PM
Johnboy12358's Avatar
ZZP 3" Intake
Anyone have any experience with this intake?
http://www.zzperformance.com/cobalt_...=921&catid=174
Old Feb 11, 2009 | 05:09 PM
HunterKiller89's Avatar
havent even heard of it....must be new?
Old Feb 11, 2009 | 05:19 PM
Pyros777's Avatar
Says: (New - 10/17/2008)
looks pretty good. wonder if it clears the brake lines on 07 models.
Old Feb 11, 2009 | 05:21 PM
Black SS/SC 06's Avatar
Ya it must be new. The only thing i dont like about it is it's a 2 piece. It doesnt say if it is stainless or aluminum.
Old Feb 11, 2009 | 05:25 PM
I need one thats stainless, I have the injen which is Al and I think its causing problems. Maybe has a hole in it. (This is relating back to my other thread about scary ass sounds)
Old Feb 11, 2009 | 05:26 PM
My injen got a hole in it. Stainless FTW lol
Old Feb 11, 2009 | 05:35 PM
SSdan's Avatar
Must be aluminum, stainless should be a little more $
Which intake do you run? Stainless?
I see you have the RAW one... how is it? How long have you had it?
Old Feb 11, 2009 | 05:45 PM
Pyros777's Avatar
The RAW intake is damn good. Had to bend my brake lines a bit because I have an 07, but other than that fitment is perfect.
Not sure if it is still available for purchase though...
Heres a pic:
Old Feb 11, 2009 | 05:49 PM
I like the RAW. You just have to make sure that the clamps are as tight as possible since its is a two piece design. RD Fabs has a one piece stainless design.
tdipowered's Avatar
not stealin the thread but ur wheels look so sick!! ive been eyeballin them online since they came out..how much do they weigh?
Old Feb 11, 2009 | 05:57 PM
tire rack hasnt posted the weight yet. each package was like 28 lbs so a little less than that im assuming lol. i didnt actually weigh them haha. i wasnt that concerned
Old Feb 11, 2009 | 06:06 PM
tdipowered's Avatar
thats not bad with tires or no?
Old Feb 11, 2009 | 06:24 PM
nope lol
Old Feb 11, 2009 | 06:26 PM
ShortStack's Avatar
Its probly alot less expensive because it is two piece.. it makes it a little easier to make, and fit...
nothing wrong with that design.
Old Feb 11, 2009 | 06:29 PM
Yea there is when the lower half falls off and your car wont run and goes into limp mode. Im not the only one that this has happened to. A one piece design is way better and Im speaking from experience. The Injen would be a much better intake if it was made from stainless. Any intake for the ss/sc is going to rub somewhere. Its just the way the car is set up.
Old Feb 11, 2009 | 06:30 PM
question for you tuners... wouldnt upgrading to a larger MAF pipe like with these 3" intakes throw off MAF readings?
Old Feb 11, 2009 | 06:32 PM
ShortStack's Avatar
Hmm.. i guess it could fall off... never thought of that...
im sure that can be prevented...
Old Feb 11, 2009 | 06:36 PM
Im not a tuning expert by any means, but its just common sense that it would mess with the MAF readings. So a tune would help
yes i have mine rigged a few different ways
zip ties ftw!
Last edited by Black SS/SC 06; Feb 11, 2009 at 06:38 PM. Reason: Automerged Doublepost
Old Feb 11, 2009 | 08:02 PM
SSPainter's Avatar
ive always had good luck with ZZP
Old Feb 11, 2009 | 08:47 PM
does your 3" intake throw cels at all? I'd really rather not have to mess with a cel if I can avoid it
Old Feb 11, 2009 | 09:00 PM
Pyros777's Avatar
Mine doesn't, and there is zero chance the bottom half will ever fall off as long as you assemble it correctly.
Old Feb 11, 2009 | 09:05 PM
i think my tire actually rubbed against it somehow and thats what caused it to fall off. i must of had it positioned the wrong way or something. idk it was kind of weird. i have since rigged it so it wouldnt happen again and havent had any problems.
yea mine didnt cause any CEL's
Last edited by Black SS/SC 06; Feb 11, 2009 at 09:05 PM. Reason: Automerged Doublepost
Old Feb 11, 2009 | 09:35 PM
no, i knew u could retune if it does throw anything off. My issue is my entire tune is MAF driven, so if I got a 3" intake, and it messed wioth the MAF readings, then I would need to pay for another tune as well
Old Feb 11, 2009 | 09:51 PM
what intake are you currently using?
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
