zzp cai
Old Mar 1, 2011 | 11:46 PM
joe0016's Avatar
zzp cai
does anybody think injen's hydroshield will fit just fine on zzp's intake??
Old Mar 1, 2011 | 11:53 PM
87gn06gto07irl's Avatar
K&n makes one.
Old Mar 2, 2011 | 07:14 AM
Staged07SS's Avatar
Administrator
Administrator
It depends on the size of the filter.
ZZP uses a larger filter on their intake so I'm going to say no. Search the part number for the K&N filter ZZP uses. K&N should have a hydroshield for it.
Old Mar 2, 2011 | 11:51 AM
insylem's Avatar
K&N does make a drycharger that fits. It's not spifically fitted for that filter but it still fits, I have the PN written down somewhere if I can find it, Ill post it.
Old Mar 2, 2011 | 12:05 PM
insylem's Avatar
Found it:
K&N Dry Charger PN E-4710DK
Is what I have on my K&N Filter that came with my ZZP Intake.
FYI: K&N Dry Charger = Hydroshield. Just different company, different name.
Old Mar 2, 2011 | 12:14 PM
BLue NoTe's Avatar
Would ZZP's intake smooth out the crappy idle I get with my ebay intake that is grinding a hole in itself? They seem to think its all that
Old Mar 2, 2011 | 12:28 PM
insylem's Avatar
It's possible..... Id also check/ clean your Throttle body though too.
Old Mar 2, 2011 | 12:30 PM
Staged07SS's Avatar
Administrator
Administrator
There are other issues that can cause crappy idle. It may not be the intake.
Have you ever cleaned your throttle body? If not I advise you to. The oil blow by from the engine's crank case breather tends to "gum" up the trottle body causing rough idle.
What injectors are you running? 60lb injectors are also known to be a cause of rough idle if not tuned perfectly.
Old Mar 2, 2011 | 01:21 PM
BLue NoTe's Avatar
Yeah I read the sticky, the throttles pretty clean but ill blast it again today. I have 60s and a custom tune but thats just how I bought it, had nothing to do with the install of either one
Old Mar 2, 2011 | 01:27 PM
Staged07SS's Avatar
Administrator
Administrator
Well, 60's are known to have a "rough" idle if not dialed in perfectly. That could be your issue. Also, check your MAF sensor. It may need to be cleaned as well.
Old Mar 2, 2011 | 06:55 PM
'07SCSS's Avatar
I know this is going to sound dumb to ask, I got the injen intake and wanting to go with a different type. Is the ZZP or K&N intake a better intake to go with?
Old Mar 2, 2011 | 07:11 PM
mrbelvedere's Avatar
clean the map sensor also if the car wasent tuned with your ebay intake the maf is probably off
Old Mar 2, 2011 | 11:54 PM
insylem's Avatar
Before this was threadjacked to a "rough idle" thread,
did Joe0016 ever get the PN for the K&N Dry Charger a few posts up?
Old Mar 3, 2011 | 12:24 AM
rephrase's Avatar
Found it:
lol
Old Mar 4, 2011 | 03:52 PM
joe0016's Avatar
Found it:
Thanks man
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
