Zzp cai
any and all. is there one better out there? would you say ingen, k&n, AEM? or def go wit the ZZP. also a little worried about a CAI and water getting in. Not a lot of flodding around me but puddles can be an issue (live in South Philly currently
i just realized i posted this in the completely wrong section... woops! anyways, does anyone with another brand CAI have any input? why did you not choose zzp? etc... also, what are peoples zzp gains looking to be?
do you want just power? save your money and do airbox mod, stock intake is already 3inch. Do you want whine? buy a 3 inch aftermarket intake, I dont think ZZP makes theirs anymore though
Kev, ZZP still makes them. I think they even have a polished version now as well.
Do they have a piece that bolts inside the fender well? I cant tell from the picture but it does not seem so. I am looking to get rid of mine for the same reason
ZZP would prob give you a better explanation as well.
I've seen one installed before.
i wonder if its worth going from my injen to a 3" zzp for whine reasons alone..
either way my maf bung is screwed on my injen and the metals all scratched to hell so i'm considering a zzp anyway
yes it does, you gotta drill a hole in there, but its quite easy. And realistically, its an intake, pretty simple, the only thing theres has above everyone elses is the maf location, seems to not set off a check engine light, and run well with the readings. Ottp makes a 3 inch intake as well, they will probably hook you up with a deal, so you could probably save some money with that route. But on the other hand, zzp has the toppest of the top notch customer service. Either way, they are both intakes, and both the sme size. If you really want to know, flow tested, the stock intake with an airbox mod moves the most air based on testing...
