ZZP cam problems
Old May 15, 2013 | 08:23 PM
dwarrick's Avatar
ZZP cam problems
Hey guys
I am not quite sure what is going on with my head. Here are the specs:
LSJ head
Supertech 75lb springs
LNF rockers
Stock lash adjusters
ZZP stage 2 came
Got the valves, seals, springs in fine no problem. Dropped in the adjusters, rockers and cams. Tighten cams as per spec
Now the cams will turn but it seems they too large? They start to turn and just stop. It looks like the valve springs are almost fully compressed and the lobe isnt even close to bringing the valves to the full open position.
Cams are installed in the correct bank as per the inscribing.
Timing chain is off, and the valves are not hitting the pistons
I am at a loss
Old May 15, 2013 | 08:28 PM
Sunburst_SS's Avatar
how do you know the valves are not hitting the pistons? If you have the head bolted down and the timing chain is off.......if you have some pistons at tdc, then the valves are going to hit
Old May 15, 2013 | 08:41 PM
dwarrick's Avatar
When I had the head off I rotated the engine so all the pistons are even in the middle of their stoke. Also if I put a long screw driver down the plug holes it goes in the same length in all 4 cylinders
Old May 15, 2013 | 08:53 PM
BLAZIN07SS's Avatar
I'm too JDM for you
contact zzp. it looks like comp made an error on the last set of cams for zzp and the base circle is too large
Old May 15, 2013 | 09:08 PM
Bluelightning's Avatar
Got Bewst?
Yep this. Measure the base circle of the cams. Stock is 1.180". Serveral on here including myself have incorrect cut cams and the base circle is larger pushing the valves down. I just sent mine back today.
But you said it's pushing them to the full open position at TDC? That's not right. Even with the cams being out of spec.
Old May 15, 2013 | 10:08 PM
dwarrick's Avatar
I can't even get the valves to open all the way. I think the springs are fully compressed and that is why the cams won't move any more
I call them up tomorrow. Thanks guys
Old May 16, 2013 | 12:44 AM
mrbelvedere's Avatar
you want to have .040 or more clearance between the spring coils when at full lift you can check with a feeler guage also did you lubricate the cam bearing journals and associated valve train parts when rolling over roll slow and measure as you go
Old May 16, 2013 | 12:50 AM
cobaltss#01's Avatar
W o w!
Old May 16, 2013 | 12:20 PM
dwarrick's Avatar
cams were built wrong. Thanks for the help guys!
Old May 16, 2013 | 12:45 PM
Staged07SS's Avatar
Administrator
Administrator
Yikes.... I can't believe the number of S2 cams that were ground wrong.
I hope everyone with this issue gets the problem resolved, and sent new (correct) cams.
Old May 16, 2013 | 12:48 PM
jonathan923's Avatar
damm this is some **** going on with all the cam problems. sucks for you guys that have gone through this troubles..
Old May 16, 2013 | 01:49 PM
JapEatr's Avatar
South Central *********
Go to BDC and then rotat the cams
This without chain if course
Old May 16, 2013 | 03:06 PM
you cant 2 down bdc 2 up tdc gotta set it ms(mid stroke)
Old May 16, 2013 | 03:09 PM
Hockeyman's Avatar
Glad my set was good. Good luck OP
Old May 16, 2013 | 04:28 PM
Zooomer's Avatar
Supporting Vendor
It's appearing several cams were done with .020 too large of base circle.
It is not enough to cause valves to hit pistons and in many cases the cars run but are down on power as the valves don't fully close.
We're working on the issue and taking care of customers as reported. We're measuring all the cams from here on out before shipping them.
To the OP, if you can't turn the motor over, it's possible you have coil bind in the springs. Even if you change cams and correct that issue, running that close on coil bind isn't safe. It would mean that you are less than .020 from bind.
Old May 16, 2013 | 04:49 PM
Got Bewst?
ETA on new cams?
Old Sep 8, 2013 | 12:56 AM
Tennpenn83's Avatar
I'm going to bump this thread. I just swapped out my ZZP Stage 2 supercharged cams back to stock. I measured the base circle on the ZZP cams, and it was indeed about .020" larger than spec. I will be in contact with ZZP, I am not overly mad or complaining, I understand these things happen. Hopefully we can get these exchanged quickly.
Old Sep 8, 2013 | 12:30 PM
advise's Avatar
Ya I was one off the first to figure out this problem when we couldn't tune my car and it ran full lean zzp should help you
Old Sep 8, 2013 | 07:10 PM
Tennpenn83's Avatar
Thanks for posting and helping the others who were unaware of this. I probably would never have known otherwise.
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
