ZZP Did What?
Old 04-16-2011, 07:21 PM
  #426
Supporting Vendor
Zooomer's Avatar
Originally Posted by elecblue06
just a suggestion.. but you should mention what your "low compression" and "high compression" CR's are
Thanks. Have the list on my desk but forgot to add it.
Old 04-21-2011, 09:09 PM
  #427
Driver1's Avatar
I am so glad my car is in YOUR shop right now and not with someone else.
What was the ignition problem on #1? Coil, weak cap?
Mike P
Old 04-21-2011, 10:17 PM
  #428
Matt M's Avatar
Mike P
It was just a bad plug, but we are still investigating other issues as well.
Old 04-22-2011, 07:45 AM
  #429
2010redrocket's Avatar
Hey Ryan did you get the 2.4 in your car yet???
Old 04-22-2011, 10:34 AM
  #430
Matt M's Avatar
Yes, it is in. We did some baseline pulls the other day. We had to make some adjustments, but we will be doing some more dyno pulls today.
Old 04-22-2011, 08:47 PM
  #431
Bl4des's Avatar
so how did today go how much power have you made so far
Old 04-23-2011, 12:31 AM
  #432
Supporting Vendor
Zooomer's Avatar
Break in runs were over 500WHP with boost in the teens.
Old 04-23-2011, 08:46 AM
  #433
elecblue06's Avatar
LAWLZ good enough for me .. thats more then i'll be looking for on my car lol
Old 04-23-2011, 08:57 AM
  #434
tityrous's Avatar
Nice job ZZP! Looking forward to seeing more videos.
Old 04-23-2011, 12:35 PM
  #435
Matt M's Avatar
The highest power we put down on the 2.4 so far is 570 at a little under 21psi.
Old 04-23-2011, 01:31 PM
  #436
JustACobalt's Avatar
is that with the s366? whens the boost coming in at?
Old 04-23-2011, 01:34 PM
  #437
elecblue06's Avatar
lol totally winning ..
Old 04-23-2011, 01:35 PM
  #438
RoadconeTuning's Avatar
Since no one has asked about it yet... have you guys considered doing a 2.4L block with a 2.0L crank so you'd get a Longrod setup? seems to have been working for the evo guys... 2.0LR setup with uber ported head and a S372 turbo... DO EEEEEEEEEETTTTTT!
i'm very impressed with the numbers you guys are making and i dont know why people have issues with you guys, the few people i know that have dealt with you directly have said you're all just a bunch of car guys who happen to run a shop and be cool as hell.
Old 04-23-2011, 03:36 PM
  #439
Matt M's Avatar
Yes, on the 366. The boost comes in a little sooner than it did with the 2.0. It has 18psi by 4500 RPM. Remember, though- this turbo supported almost 900 at the wheels. This exhaust wheel is not what you would run on a 500-600whp setup. Actually, I would recommend a 362 with an exhaust wheel a couple sizes smaller for a 600whp 2.4.
Old 04-23-2011, 03:37 PM
  #440
EXsoccer1921's Avatar
ready to buy...
Old 04-23-2011, 03:39 PM
  #441
Matt M's Avatar
Yes, we have a set of rods here that will mate up 2.4 pistons to a 2.0 crank, so the rod ratio is even better than the 2.0. 1000whp on an S372 2.1 liter at 9000 RPM sounds like fun.
Old 04-23-2011, 03:40 PM
  #442
tityrous's Avatar
ready to buy...
Are you building or selling?
Old 04-23-2011, 03:42 PM
  #443
building if i can ever get a hold of anyone zoom never responds and ryans always busy pickin up chicks in his car.
Old 04-23-2011, 03:44 PM
  #444
cars been down for about a month now. ready to do something with it
Old 04-23-2011, 05:51 PM
  #445
straying off topic a bit but zzp are you guys looking into releasing a higher flow injection system for the lnf? is it possible?
Old 04-23-2011, 11:50 PM
  #446
Supporting Vendor
Zooomer's Avatar
We have many fuel items in the works for LSJ and LNF
Old 04-25-2011, 03:02 AM
  #447
yeeee!! i burnt a hole in piston #4 because i ran lean (not enough fuel) and really need somebody to develop some injectors or a higher flow pump
Old 04-25-2011, 03:17 AM
  #448
ralliartist's Avatar
There is a higher flowing pump for the LNF already.....
The Home of WERKSracing products!
Old 04-25-2011, 03:31 AM
  #449
mkriebs's Avatar
Thats actually a drop in for all Ecotecs, just for everyone's info. Can PM me for even more info.
Old 04-25-2011, 06:43 AM
  #450
HunterKiller89's Avatar
thats a low pressure pump. We need a high pressure pump....
Quick Reply: ZZP Did What?
