ZZP Did What?
#478
Great job ZZP! You guys honestly set the bar for the Cobalt community.
Side note: Look at all of the ZZP haters who are in here poking around and such after they continually bash them. Oh it makes me laugh. Maybe it's because they finally realized otherrrrrrrrrrrr companies can't compare.
#487
I just finished reading the entire thread and would like to add my two cents. It is simply amazing that a company has conducted the R&D for this platform considering the demographics. I'm privy to some R&D with products on one of the largest delivery fleets in the world and state that it is labor intensive. Congratulations!!
Call me old school but I love Zoomer's posts. I have spent a lot of time around some tough NCOs while in the military and some of our high level managers in various assignments. They don't bullshit and tell you like it is. Sometimes your feelings may get hurt but I have found you learn from what was stated. They may not be 100% accurate and it is not exactly textbook application of people skills, but it works.
I have been pricing the expense of building an LSJ to my horsepower and torque goals the last few weeks. It appears I cannot touch my buld for the price of ZZP's.....not to mention the reliability they have provided in this thread. I know where I will be spending my hard earned $$ and seek guidance on the build.
The one thing I have been pondering is the possibility of a rear wheel drive converstion for the balt using the Solstice drivetrain. Maybe that is a project you may consider in the future.
#489
Curious as to how you accomplished this? Did you remove the steel sleave inside the oil filter housing and block off the holes? Or did you mock up your own plate with fittings to run an aftermarket external cooler. (Similer to the set-up that sand-rail guy makes)
Hahaha then again I can understand if you don't tell me.
#496
Well I don't think welding to the block would be a good idea, unless I'm reading what you wrote wrong. I was going to tap it but I don't wanna run a cooler at all, I have a new idea using a block of machined aluminum.
I'm mostly curious to see if they pulled the steel sleave out...which is what I originaly wanted to do...problem is I'm worried about cracking the block in the process.
#498
I think your exact words when you left were
"Ps. ZZP I didn't contact you about a build because quite frankly I am quite capable to build my own motor/source my own parts....pretty basic stuff boys. Not to mention other than these rods there is nothing you guys sell that I would be interest in buying, I'm building an all-motor car, not a boost build"
#499
your seriously going to come back into this thread after your posts last time and ask for information. Give your head a shake
#500
Did I ask them to solve the problem for me? No.
I already have a soloution to this problem using a block of machined aluminum as I previously mentioned.
I simply asked them how they went about solving the same issue out of curiousity.
Settle down, don't take the internet so seriously.
