zzp f40 kit
zzp f40 kit
http://shop.zzperformance.com/store/...onversion.aspx
http://shop.zzperformance.com/store/...x?cleartheme=1
a different clutch would probably most defiantly be needed, the saab f40 uses a 23 spline input shaft. i really want more info on what clutch and pressure plate they use, as well as the pressure plate.
They list the Buick and Saab 6 speed as interchangable
ive been working on a auto to mani swap using the f40, the v6 f40 which btw is a revised version circa 2006-7 has a 20 tooth count as well as different shift detents, and speculation that they improved the strength of the 5th gear syncro. the I4 has a 23 tooth count on it, i know you have one for sale i was actually going to maybe buy that hahah, but actually can you count the number of teeth on the input shaft? also do you know the width of the bell housing?
