ZZP HE install
ZZP HE install
Im having a **** load of problems getting things to line up. The side brackets dont seem to wanna go over the bolt sticking out. Any advice for install, can i just cut those off without worrying about structural integrity?
No, do not cut them off. Mine did the same thing as yours. If you get the h/e on there as if you were to mount it, see if the corners[of the h/e] are hitting on some extra material on the crashbar, preventing it from going up far enough to mount those outer tabs on the studs. I just removed 1/2 inch of this "extra material" on each side and it mounts up perfect. If you don't, it will likely end up like this...
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/my-zzp-heat-exchanger-done-189845/
lol after reading his post i was about to link that page to it to.
to the op, i had the same problem too, i just moved the corner tabs around a little till they lined up. took me a couple hours to get it right
edit: also i heard it is a lot easier if you remove the bumper
i took and drilled the holes on the h/e a little bit bigger and used a bigger washer, i dont think any of them fit correctly. takin the bumper off will save u soooooooo many headaches and time.
are you talking about the fitting on the side for the water hose? try putting it in before you install it
i didnt put it in yet,but i tried screwing the fitting in and u cant even get a full turn on it and it hits the top braket? and i dont want to ben the braket because i dont want to mess it up and bend it to the wrong spot or worse break the welds.
OP take the bumper off, its not hard and will save you time and a headache.
You dont need too, i tried it again last night with the car in the air and used a jack to help hold it up and it went on first try. Just go to autozone and get straight fittings for it. ZZP decieded not to send me any so thats what i did.
