ZZP HE install
Old Oct 7, 2009 | 09:59 PM
Chase0224's Avatar
ZZP HE install
Im having a **** load of problems getting things to line up. The side brackets dont seem to wanna go over the bolt sticking out. Any advice for install, can i just cut those off without worrying about structural integrity?
Old Oct 7, 2009 | 10:39 PM
mtbrent's Avatar
No, do not cut them off. Mine did the same thing as yours. If you get the h/e on there as if you were to mount it, see if the corners[of the h/e] are hitting on some extra material on the crashbar, preventing it from going up far enough to mount those outer tabs on the studs. I just removed 1/2 inch of this "extra material" on each side and it mounts up perfect. If you don't, it will likely end up like this...
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/my-zzp-heat-exchanger-done-189845/
Old Oct 8, 2009 | 12:52 AM
06cobalt racer's Avatar
lol after reading his post i was about to link that page to it to.
to the op, i had the same problem too, i just moved the corner tabs around a little till they lined up. took me a couple hours to get it right
edit: also i heard it is a lot easier if you remove the bumper
Old Oct 8, 2009 | 06:52 AM
Chase0224's Avatar
Really dont wanna remove the bumper. On the corner tabs, i was looking at them this morning and can see where the screw was rubbing at right near the hole from zzp, im just gonna drill another if i cant bend the tabs around to get it lined up.
Old Oct 8, 2009 | 10:27 AM
you should be able to bend them around. i just took vice gripes and played with them a little
Old Oct 8, 2009 | 02:59 PM
ssscs10's Avatar
i took and drilled the holes on the h/e a little bit bigger and used a bigger washer, i dont think any of them fit correctly. takin the bumper off will save u soooooooo many headaches and time.
Old Oct 8, 2009 | 03:04 PM
Bad05SS's Avatar
lol wow how does mom and dad feel about that?
Old Oct 8, 2009 | 06:24 PM
Black SS 07's Avatar
bend the tabs enough to get them over... put the nut on.. it will all line up after you tighten it down..
Old Oct 8, 2009 | 06:34 PM
what?? did i miss something? lol
Old Oct 8, 2009 | 09:08 PM
*boostinss*'s Avatar
i just bought the zzp s2 heat exchanger. my question it how in the hell can u screw that top 90 degree fitting in the side? you can only go a 1/4 turn then it hits the mounting bracket.
Old Oct 8, 2009 | 10:09 PM
Chase0224's Avatar
Thats what i was thinking?
Got it to go first try today, no idea why it was being such a pain yesterday.
Old Oct 8, 2009 | 10:10 PM
Black SS/SC 06's Avatar
Pics?
Old Oct 8, 2009 | 10:14 PM
are you talking about the fitting on the side for the water hose? try putting it in before you install it
Old Oct 8, 2009 | 10:54 PM
i didnt put it in yet,but i tried screwing the fitting in and u cant even get a full turn on it and it hits the top braket? and i dont want to ben the braket because i dont want to mess it up and bend it to the wrong spot or worse break the welds.
Old Oct 8, 2009 | 11:28 PM
take a pic and post it up
Old Oct 8, 2009 | 11:36 PM
MikeyB's Avatar
Bend the bracket out the way, thats what i did
OP take the bumper off, its not hard and will save you time and a headache.
Old Oct 8, 2009 | 11:39 PM
damien's Avatar
Wow so many people can't figure out how to install this thing..It's piece of cake!
Old Oct 8, 2009 | 11:42 PM
Hodz's Avatar
^^^^ maybe someone should make a how to on this... perhaps that would cut down on these repeated posts of people not being able to install them correctly?
Old Oct 9, 2009 | 06:54 AM
Chase0224's Avatar
You dont need too, i tried it again last night with the car in the air and used a jack to help hold it up and it went on first try. Just go to autozone and get straight fittings for it. ZZP decieded not to send me any so thats what i did.
Old Oct 9, 2009 | 09:00 AM
ssscs10's Avatar
i wouldnt trust those plastic fittings for nothing. get the brass straight fittings and be done with it.
Old Oct 9, 2009 | 10:00 AM
Agreed. I took my bumper off when I installed my H/E. No problems.
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
