ZZP Pulley Tensioner
Old Aug 26, 2007 | 08:36 PM
invisible's Avatar
Question ZZP Pulley Tensioner
Please does anyone no how to tension this damn thing, i have no clue cause it doesnt have a place to put tension on it so you can slip the belt on.
Old Aug 26, 2007 | 08:37 PM
Element2.4's Avatar
I thought it had 3 holes. You just use which hole gives you the tightest tension on the belt.
Old Aug 26, 2007 | 08:41 PM
invisible's Avatar
Yes it does but you still have to tension it.
Old Aug 26, 2007 | 08:43 PM
Element2.4's Avatar
Oh now I get what your saying.... There is no hump like the old one. I had to use a pulleyboyz tensioner tool
Old Aug 26, 2007 | 08:47 PM
invisible's Avatar
yea i looked for one but no one has one in the **** hole i live in, i was just curious if anyone else had any ideas, i called zzp and the said i could buy one from the for another 150$, but hell with that. but without the tensioner i am only at 15psi and it says with a 2.8 pulley i supposed to be at 17.5psi
+rep for u for trying to help thanx
Old Aug 26, 2007 | 08:51 PM
Element2.4's Avatar
No problem man. Check out pulleyboyz I think its like 100 bucks but its a very usefull tool. Once I had to friends push on the tensioner pulley to give just enough slack so I could get the belt over. I wouldnt recommend this though because you can jack up your other pulley.
Old Aug 26, 2007 | 11:02 PM
invisible's Avatar
haha ok thanx, anymore advice would help.
Anyone else have any ideas or has anyone got it on
Oct 20, 2015 09:56 PM
no_ss
Oct 18, 2015 11:58 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
