zzp s3 h/e vs. ottp h/e
Okay cat-fight aside, I have the ZZP S3 h/e and I like it just fine. It's been on for a while now and I've had zero issues. Install was very easy and it came with everything you need to do it. When I did mine I took off the bumper since that only takes like 10 minutes and it makes your life a lot easier than trying to bend around all kinds of stuff. I bought the ZZP one because at the time it was the only h/e that totally filled out the lower grille. That being said, I've never used OTTP's h/e but I'm sure it's just as good as the ZZP unit.
Zzp zzp zzp zzp the only h.e worth getting. Ottp has had nothing but issues with there nipples at the bottom.... They were crap and prob still are because all I hear about them are Negative remarks. Zzp is the way to go
You never answered my question .... See post #19.
P.S. Serious question not being an ass, so don't get defensive.
Replace with a 1/4" NPT plug = zero issues. Not really a big deal, nor a reason to say their heat exchanger is crap. I agree their past version are no where near as good as ZZP's S3, but their newest version is very nice no matter what people say. Everyone is judging them by their older versions, which were indeed chinese cores, and bar & plate design (which is a shitty design for a heat exchanger). Their newest is a dual pass radiator style core just like ZZP's. They are both good heat exchangers.
Last edited by Staged07SS; Jul 19, 2010 at 01:48 PM. Reason: Automerged Doublepost
Well my iat2s are about 15-20 degrees warmer then ambiant, and i run a 2.6 with no other cooling mods other then the s3. meth if for bosot and i dont even have it anymore lol...
Oh yeah and when i ran meth i only used 100% meth and not any mix so three wasnt really any cooling other then a few degress
Last edited by Chevycobaltss3; Jul 19, 2010 at 01:43 PM. Reason: Automerged Doublepost
What are your IAT2's at WOT after a pull?
Cruising I see 8-10 deg above iat1. crusing doesnt matter though, comparing iat's with others in general doesn't matter unless conditions are the same between compared cars.
WOT end of 3rd I believe 30-40 deg above iat1 off hand without looking at a log...
90-100 deg weather. prob about 30-50% humidity.
Not a problem haha. This forum has been shot to hell in the last year because so many people have no respect for each other on here and can't understand if someone else has a different opinion. It get's old
they get to about 40 -60 over ambient for two gear pulls like say from 2 to 3rd. Pulley size should actually because you are still incresing flow. If you think about it. The sc is spinning fast so it might make it a little warmer. or somewhat cooler. Im pretty sure i am correct!! And about the mature quote ontop, correct. But start looking at yourself bro befroe you talk!! I was trying to help and you came in here thinking you knew everything. Ive dealt with almost every product on this earth known to man for cobalts and ZZP STANDS OUT for there more superior products. And i am not saying OTTP is not godd, or there products suck, but what i am saying is in the cobalt world, ZZP IS # 1
Last edited by Staged07SS; Jul 19, 2010 at 02:21 PM. Reason: Automerged Doublepost
Yeah I said mine are lower, but they're to be taken with a grain of salt, they're like a dyno # basically. Just measuring something different. LOL.
I do also have dual pass endplate...I assumed since you had st3 stuff you had it also. That has littler to do with temp drop like the h/e and moreso bettering the system and recovering quicker though.
Allright i first started working with toyota as a diag tech, and then i decided to jump to a damn GM, Last mistake ill make lol. Great car for about a day until somthing else happens lol. staged i wasnt meaning you knew everything i was meaning you knew everything about the h.es.... I built my car from the bottom to top, i know what there is, i know what ther isnt, ive done many ss here in kentucky, ive put different types of h.es, ive tuned corvettes all the way to a cavi lol. in the gm market soi do know what i am talking about.l And like i said before OTTP is just another place to get parts. I hope ottp changed eevrything about there h.e.. larger core no damn nipple on the bottom, larger fluid tanks. But your iats are gonna also be affected by, gear selected, ( Pulley size) Exuast, intake size, porting of head or sc. My iats2 in third gear doing 75 stay about 10 over ambient. lol..
That's why it's tough to compare IAT2's and Heat Exchangers. Their are so many factors to take into consideration. Just like 05Slowline said .... Comparing IAT2's is like comapring dyno numbers. To many factors that end up changing the final outcome
correcto mundo, each thereown. Cooling mods matter why dont a company make a ac system that is only for the ss. But it dont run off the engine, but say like a elitrical motor. And then itll always be cool, and your iat2 will be cooler then ambient. lol for real...
I like the S3 it fills in the bumper nice but I went with the ottp heat exchanger because I got the stage 2 kit from them and the heat exchanger comes out to only 150 dollars versus the S3's 220 dollars.
Being that OTT claimed to make their HE's before and it was proved they were just chinese cores, I can see why people would be leary of believing them now. Maybe they are designed by OTT? Don't know. At ZZP we build ours from scratch. We buy raw core material, cut it to size, bend the end tanks from raw stock, etc.
Coming out with 4 different HE's and claiming each one is the end all be all and way better than that last one reminds me of a Katt Williams skit about weed. And by OTT's admission, they will design a 5th and 6th version in the future...
http://www.youtube.com/watch?v=IJMvPU1a1vI
