Zzp stage 3 keeps throwing codes
Old Sep 15, 2011 | 11:57 AM
eddi's Avatar
So I just recently installed zzp's stage 3, I have the 60#injectors aem intake, dualpass end plate slp exhaust, 2.9 pulley. She started to throw the p0171 code so I pulled everthing apart checked vac lines, gaskets and injectors for proper fit and all that checks out good, but I keep throwing the code, it'll clear itself when I'm driving on the freeway but in stop and go it comes on. Could I have a problem with the tune? I don't have anyway to log anything but I know a guy that can hook me up with a tune. I'm at a loss here guys any help is greatly appreciated.
Old Sep 15, 2011 | 02:22 PM
SCcobaltSS's Avatar
Fuel trims are lean. You need a custom tune.
Old Sep 15, 2011 | 02:28 PM
Chevycobaltss3's Avatar
You need a custom tune but anything can cause the p0171.. Vacuum leak to a leak to the 02 sensor can cause this along with a bad ic pump.... Hotter air will skew fuwl trims alot
Old Sep 15, 2011 | 05:26 PM
eddi's Avatar
So after reading around it is really looking like a tune is in order, how bad would it be on her by producing boost?
Old Sep 15, 2011 | 06:26 PM
SCcobaltSS's Avatar
Well its running lean now, as the code says, so it could possibly be lean up top too. I wouldnt push your luck lean is no good.
Old Sep 15, 2011 | 07:44 PM
troyss's Avatar
Zzp tunes run realll rich
Being lean I doubt that
Old Sep 17, 2011 | 02:31 PM
eddi's Avatar
in all technicallities it is rich inside the cylinder, but the code from the ECU is for lean, the ecu adds more fuel to the cylinder trying to compensate for the lean reading from the sensors, been reading around on it. the strangest thing is its only throwing it at low rpms, and city driving, on the freeway it clears itself and runs like a scalded dog..
Old Sep 17, 2011 | 02:49 PM
mrbelvedere's Avatar
just go beat on it
Old Sep 17, 2011 | 02:50 PM
Sharkey's Avatar
if its throwing the code at low rpm, specifically under decel conditions, its likely a vacuum leak somewhere. did you just look at everything, or did you check it with a gas (propane tourch, butane, accetalene, etc)? thats the proper way to check for vacuum leaks.
Old Sep 17, 2011 | 05:08 PM
REDi DEViSTATOR's Avatar
The best way to find out if your actually lean is to get a wideband. Anything else is a shot in the dark...
Old Sep 21, 2011 | 10:07 AM
eddi's Avatar
well i did a controlled smoke test, held a hose blowing smoke by all the lines, manifold to head, and the blower to manifold, looking for any distortion in the smoke, none observed, then i just said **** pulled everthing apart, and reassembled with proper torque specs, @ REDi Im looking into getting a interceptor wide band
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
