ZZP Stealth heat exchanger
Old Jan 10, 2013 | 01:13 PM
killer!!!
Old Jan 10, 2013 | 01:39 PM
zrated89's Avatar
mines stayed about 8-12 deg max while cruising
Old Jan 10, 2013 | 01:42 PM
Vander Nars's Avatar
people that are giving ur degrees could atleast post ur cooling mods.
Old Jan 10, 2013 | 02:19 PM
ThexGovenor's Avatar
Originally Posted by mrbelvedere
I was talking to yellowsupercharged06 about the post he had quoted.
Old Jan 10, 2013 | 04:42 PM
Pleass's Avatar
Option b is one of the best options for the LSJ systems.
Also would like to see how this unit compares to the one modern performance is now offering. But unless someone does an A-B comparison, we will never know as Stage pointed out.
MP are selling mishimoto radiators, not HE
Old Jan 10, 2013 | 06:17 PM
574's Avatar
574
Anyone else get confused when looking at THXGOV posts and Vanders posts? Haha your sigs are identical
Old Jan 10, 2013 | 06:53 PM
YelCal7's Avatar
^^^LMAO! Base on TRUE STORY!^^^
Old Jan 10, 2013 | 07:36 PM
Powell Race Parts's Avatar
single pass gen 1 race griffin, option b TVS 2.9; 20 degrees diff., after 5 consecutive dyno pulls over 35 minutes in 75 degree ambient. Area47 wheeling the dyno.
Old Jan 10, 2013 | 09:21 PM
I guess ill have to change my sig
Old Jan 10, 2013 | 11:28 PM
SSfamilywagon's Avatar
So this h/e seems to be all show and no go. Looks like people are reporting the same average temps as any other frt mount.
Heck I had better results with less cooling mods. Dual pass and opt b does wonders. I can't seem to comprehend why people don't just do an Opt b. Frt mounts and flow throughs are a waste.
Old Jan 10, 2013 | 11:43 PM
  #36
^^^ troof. I wonder the same thing, have for ever. New set of noobs come in and history repeats.
some of the front mounts were just terrible. ott was right up there with chiwanese crap, and ZZP cut it up and posted pictures lol; compared to theirs, which was not quite as awful ..oh well. its what people want I suppose.
let the flames begin.
Old Jan 10, 2013 | 11:52 PM
  #37
mrbelvedere's Avatar
they all seem to give the same results between iat1 and iat2 under a hard pull no matter which one you use but I bet the main difference is recovery time which to some that what its all about I still think option b is best bang for the buck
Old Jan 11, 2013 | 12:35 AM
  #38
I want le griffen for my rebuild
Old Jan 11, 2013 | 01:27 AM
  #39
I haz the griffin. Ill post some results once im all done with the build.
Old Jan 11, 2013 | 03:03 AM
  #40
Glad to see all the ignorant comments. As i stated this works better then my stock H/E.
Old Jan 11, 2013 | 04:11 AM
  #41
Pleass's Avatar
No you are
You bought an he that you thought was going to be the new hottest **** with no info on how this he works
  #42
Erick161's Avatar
Not really ignorant. H/E have always been a debate. Frankly a dual pass and option b would suffice. And if you ran meth...well then no comparison.
Old Jan 11, 2013 | 04:25 AM
  #43
Originally Posted by Pleass
No you are
Someone has to buy it to find out if it works, and it works iv already post my difference from my stock h/e and dual pass to the new h/e dual pass it is an amazing difference. I can also buy more cooling mods and have even better results but that was not the point of the info i provided it was to show the difference from stock h/e to stealth h/e.
Old Jan 11, 2013 | 07:27 AM
  #44
Staged07SS's Avatar
Administrator
Administrator
I agree to a point....
I never ran the dual pass w/o my front mount, but before my front mount cruising temps were not that good.
Once I purchased OTTP's 4th gen heat exchanger (radiator core, not that bull **** they used to sell) my cruising temps improved as well as WOT pulls.
With the addition of the GMR dual pass, recovery is almost instant.
I always ran opt. b (first cooling mod), and there has always been benefit from that.
In all honesty, I always thought about purchasing the Griffin, but how my car sits now it's not really needed. One day....
Old Jan 11, 2013 | 09:53 AM
  #45
what your not getting is since day one people have been fighting iat1 vs iat2 under a hard pull its always been a 30deg difference or more cruise temps close to the same this H.E. is no different and when you said your cruise temps were 30+ you more then likely still had air in the system
Old Jan 11, 2013 | 10:46 AM
  #46
Hockeyman's Avatar
Flow through a waste? Well, when I fill my tank up with ice for track and dyno days and my IAT temps are less than 5-10* apart I beg to differ.
Old Jan 11, 2013 | 10:51 AM
  #47
flow thru tanks are great
Old Jan 12, 2013 | 09:35 AM
  #48
sternerG85SC's Avatar
i got to agree. option B kits are nice to add coolant and bleed off the system. but most of that coolant in the reservoir is stagnant.
i replaced my option B with a Flow-thru tank and i noticed no difference in IAT1 and IAT2 while cruising. but i noticed a slightly quicker IAT2 recovery after a pull....
but ....To each his own....
For now... my Stealth H/E sits in my bedroom until spring time for install..
Im using right now ZZP dual pass, ZZP S3 H/E, ZZP phenolic intake mani spacer, Euthanasia Flow-thru tank. and my IATs range from 12-20 degrees difference from eachother while cruising depending on ambient temps. and WOT i never surpassed 135IAT2
Old Jan 12, 2013 | 11:36 AM
  #49
zrated89's Avatar
i had gm dual pass, opt B, zzp stage three front mount, zzp phenolic spacer, and was on meth inj as well
Old Jan 12, 2013 | 12:04 PM
  #50
One time i did a 50-150 pull and my iat2 was 189 ambient was like 38 or something. This was before meth however...
