00-04 ecotec head work for 05-06 ecotec head
Old Dec 21, 2009 | 12:36 PM
Jn2's Avatar
Jn2
Section8 talked me into studs, I wanted to use oem bolts since build book says they are ok for my power levels...not to mention cheaper. About the pistons I may just see if wiseco can make me a 9.5:1 piston...bc I sure as hell don't want 8.9:1...and I don't think diamond makespistons for the 2.2, I saw them for the lsj
Old Dec 21, 2009 | 02:30 PM
06_ion2's Avatar
Even with my 8.9:1 cams and head the motor needed alot more fuel up top so it has to be making more power even with the lower compression.
Old Dec 21, 2009 | 02:42 PM
Maven's Avatar
Diamond makes a 9.5:1 blower piston for the L61.....how convenient, wonder if thats why i suggested them
Old Dec 21, 2009 | 03:55 PM
Jn2's Avatar
Jn2
I checked ttr's site didn't see a l61 option, so. Checked diamods site, couldn't find one but I'm looking thru my phone so I could of missed it...what's the p#? but a 9.5 would be bettwer than 8.9
Spending my income tax, bonus and money I has led over fro
January and feburary to fund my build
Old Dec 21, 2009 | 04:27 PM
HunterKiller89's Avatar
troof. Weisco also does readily make custom piston sets. You can PM Karo about ordering them, or TTR too im sure.
Old Dec 21, 2009 | 11:25 PM
Jn2's Avatar
Jn2
Ill order the pistons lat as they are the most expensive part of the build :p buying everything over time, not at once. So first Ima have the head checked to make sure it's good for use, have it decked, 3angle valve job, and have it PnP, than imm be picking up the parts needed.
My goal for next year is to be pushing 300+whp on a tvs and a built engine, maybe after that I'll work on making the car look better :p
Old Dec 22, 2009 | 08:32 AM
BlackCobalt707's Avatar
remember to get bigger o-rings when you put the fuel injectors in. if not the injectors wont seat right and you will have a big as vacuum leak and wont idle....trust me, i had this issue and figured this out last month
Old Dec 22, 2009 | 09:50 AM
Jn2's Avatar
Jn2
i havent had a issue with my injectors not sealing right on the injector ports on the head, i run 60lbs injectors, so they are plenty long to reach inside, and they are not porting my injector ports right now i have no poblems holding boost, dont see why doing all these mods would change the amount of pressure my blower puts out...
Old Dec 22, 2009 | 02:01 PM
lucky **** lol. i couldnt figure out why my car wouldnt idle for months and come to find out the injector ports were different cause the head wasnt the same. i guess mine had a vacuum leak cause i got 42s right now..i need some 60s as well. keep a eye out for some 60s for me if you dont mind please
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
jmelton327
Sep 26, 2015 10:04 PM
