2.0 motor swap
2.0 motor swap
ok so i see on ebay you can buy a ss/sc motor with everything but axle's it comes with the ecm and everything.. would that motor go right in since the 2.0 and 2.2 use the same mounts ? and would nething need to be modded ? is it possibly ? the full swap goe's for about 2,500
but he said it came with the ECU, hmm, so basically you get the whole front clip than right? if so, check if you need the tranny, cuz if you do than you have to add that to the total cost, plus the install, in the end you might be spending more than what its worth, you'll spend a good 4k on it, i suggest gettin the turbo kit, simple bolt on...no need ot go all out and remove ****
at the very least you would need the motor, tranny, ecu, engine wiring harness and axles...I don't believe anyone has attempted it so who knows what little small things you would need. so unless you have the know how it probably wouldn't be worth it as there aren't going to be many guys that can answer any questions you would have.
a more feasible swap would be the 2.4 motor but again no one has attempted it to my knowledge.
if you've got the funds and knowledge why not though, its the same chasis so its not like it couldn't be made to work.
well its a full motor comes with everything engine harness everything trans everything but the axles .. it a whole front end basicly and i would do the work my self.. done motor swaps be4 on my other cars so that wouldnt be a problem.. im going to do more reserch and maybe do this with my income tax check this winter .
i don't see why it wouldn't work. its the same dam car other then the drive train. if its a whole front clip then it shouldn't be a problem. i think that the biggest problem is gonna be that unless you get the same wheel size your speedo will be off. please let us know how this works out. i've been thinking about it myself.
You took the words right out of my mouth. The money your going to have in the motor alone , you could put in your 2.2 and have a completely built n/a motor, then just either buy a supercharger off here, or go turbo, and smoke the crap out of the 2.0's.
ThoR294
10-04-2015 08:44 PM
