2.0 PCM on 2.2 Cobalt....
Old Sep 20, 2007 | 10:36 AM
Garrettsi's Avatar
Since 2.2 L Cobalt aren't supported by Hptuners
Is it possible to use the 2.0 L Cobalt PCM on 2.2 CObalt and now tune it?
Old Sep 20, 2007 | 10:44 AM
alleycat58's Avatar
The short answer is no, but I'll let someone who knows a helluva lot more about both engines/PCMs explain the long answer....
Old Sep 20, 2007 | 10:45 AM
Witt's Avatar
Short version: The 2.0's computer cannot communicate with the other modules installed in a 2.2.
Old Sep 20, 2007 | 10:47 AM
Garrettsi's Avatar
So there is no other solution or PCM that could be used?
Old Sep 20, 2007 | 10:50 AM
alleycat58's Avatar
Piggyback systems have been used widely for the 2.2s for quite a while, that's how all the turbo applications are tuned.
Old Sep 20, 2007 | 10:55 AM
Jimmys2007CobaltSS/C's Avatar
dat sucks that theres no tuning for the 2.2
Old Sep 20, 2007 | 10:58 AM
Sw4y1313's Avatar
Yes there is, we just dont have the luxury of using HPT. I guess its a drawback we must deal with. We paid less, so we get harder tuning. What a trade! lol
Old Sep 20, 2007 | 11:01 AM
hows ur car runnung?
Old Sep 20, 2007 | 11:03 AM
D4u2s0t's Avatar
when i looked into this in my 2.2, i was told what witt said. there are a bunch of different modules that all communicate with each other. if one doesn't communicate, they all don't work.
Old Sep 20, 2007 | 11:18 AM
Sw4y1313's Avatar
No engine in it, waiting on some more parts to come in and the forged engine is done. But it was running just fine, it was a blast.
Old Sep 20, 2007 | 06:23 PM
HunterKiller89's Avatar
the 2.2 ecu uses a CAN bus style architecture, whereas the 2.4and 2.0 ecu's dont, making them unable to communicate with just about every sensor in the car
Old Sep 20, 2007 | 06:45 PM
yellowshowbalt's Avatar
so why not take the hole harness "theres 3 total" and bcm and the pcm put those in your 2.2
Old Sep 20, 2007 | 08:41 PM
D4u2s0t's Avatar
they're all completely different parts. i would guess you couldn't do that for the same reason why you couldn't just swap parts with a totally different car, like civic, that has tuning. but i'm sure someone with more experience and knowledge about this can chime in.
Old Sep 20, 2007 | 08:50 PM
Novajoe's Avatar
that being said... it's possible, you just have to swap all the sensors, tcm, pcm, etc. I'm not sure if things like the abs control module, p/s module, evac control module, srs, etc would work if you did manage to do it.
long story short, it would be so much of a pain in the ass and cost you so much that you might as well just throw an lsj in your car and save yourself alot of headache.
Old Sep 20, 2007 | 09:58 PM
D4u2s0t's Avatar
exactly. all that work, and for what. just for the ability to tune? you don't even gain anything from swapping out all those parts. your car will be just as fast as it was before. and what are the turbo guys putting out, a little over 200 whp? it's just a **** load of work for 80 hp.
Old Sep 20, 2007 | 10:05 PM
Novajoe's Avatar
actually just the swapping alone will make your car run like ****. The tune on the 2.0 won't work for our 2.2s. You would have to add the cost of a tuning device AND tuning just to make it run right.
HEATON
Oct 16, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Sep 28, 2015 12:51 PM
