2.2 engine
2.2 engine
iam looking to putting another engine in my 06 2.2 cobalt what year engines can i use i picked up a 07 but it has a cam sensor and the valve cover is different mine dont will that make a difference and a engine out of a automatic work with a stick cause mine is a 5 speed
how do you tell what you have like i believe a cobalt engine is different then a cavalier 2.2 even though there both ecotec
Pretty sure all the bottom ends are the same so the 06 vs 07 dosent matter just use your old head.
I think the cavalier had a power steering pump on the one cam so that should be easy to tell
ok thanks i have a friend thats not going to build . i have a 08 im going to build. i'm going to use his 07 block just wanted to make sure it would work. can i use the crank in the 07 as well ? this way my car want have to sit around in a shop. i didn't no you could take the motor out from the top i was going to do it at my house, need lift to make it easy.
patooyee
Oct 1, 2015 01:07 PM
