2.2 engine
Old May 10, 2011 | 09:39 PM
jdgpuller's Avatar
2.2 engine
iam looking to putting another engine in my 06 2.2 cobalt what year engines can i use i picked up a 07 but it has a cam sensor and the valve cover is different mine dont will that make a difference and a engine out of a automatic work with a stick cause mine is a 5 speed
how do you tell what you have like i believe a cobalt engine is different then a cavalier 2.2 even though there both ecotec
Old May 11, 2011 | 08:47 PM
BLKLS's Avatar
Pretty sure all the bottom ends are the same so the 06 vs 07 dosent matter just use your old head.
I think the cavalier had a power steering pump on the one cam so that should be easy to tell
Old May 12, 2011 | 01:06 PM
j27-2's Avatar
you can only use a 06 or older l61 the 07+ have a a 58x reluctor wheel on the crank, you could just ignore the cam position sensor
Old May 13, 2011 | 04:35 PM
jdgpuller's Avatar
how about the crank is the same on a auto vs manual do i haft to buy a motor out of a 5 speed cause that is what mine is
Old May 15, 2011 | 12:32 PM
BLKLS's Avatar
That won't mater. I you get one from an auto you just take the flexplate off and put your flywheel and clutch on
Old May 15, 2011 | 04:58 PM
jdgpuller's Avatar
k all i need to do now is find one out of a 05 or 06 the first 3 letters that are on the bar code on the valve cover said TAX on my engine
Old May 15, 2011 | 05:49 PM
gbkglenn's Avatar
is the 07 & 08 2.2 the same motor ?
Old May 15, 2011 | 09:21 PM
NWAE Cobalt's Avatar
i have a bare block with crank sitting around if your interested.
Old May 15, 2011 | 09:44 PM
gbkglenn's Avatar
ok thanks i have a friend thats not going to build . i have a 08 im going to build. i'm going to use his 07 block just wanted to make sure it would work. can i use the crank in the 07 as well ? this way my car want have to sit around in a shop. i didn't no you could take the motor out from the top i was going to do it at my house, need lift to make it easy.
Old May 17, 2011 | 08:20 PM
jdgpuller's Avatar
ya iam interested what year is it i need a 05 or 06
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
