2.2 S/C Intercooler pump question
Old Nov 7, 2012 | 06:14 PM
GoofyBalt's Avatar
Where did you supercharged guys hook the intercooler pump up to for power?
Thanks in advance!
Old Nov 7, 2012 | 06:36 PM
nhanson's Avatar
I did add a fuse on to the fuel pump.
Old Nov 7, 2012 | 07:16 PM
bratboy90's Avatar
What this nerf-herder said. You can do a add-a-fuse to any fuse that turn on when the car is on and stays on...Lot of fuses under there that do it. That or it's not a bad idea to actually put it on a switch so if your drag racing you can keep it on while the car is off. You're choice really.
Old Nov 7, 2012 | 07:34 PM
nhanson's Avatar
I do want to put a switch on it eventually
Old Nov 9, 2012 | 09:00 AM
GoofyBalt's Avatar
Is there a write up on this?
Old Nov 9, 2012 | 04:01 PM
bratboy90's Avatar
I'll make one below:
Things you'll need:
Automotive Wiring
Wire Cutters
Crimps
IC Pump
Add-a-Fuse
1. Go To Fuse Box
2. Find Fuel Pump Fuse
3. Remove Fuse
4. Insert Add-a-fuse
5. Use automotive wiring and crimps to connect this add-a-fuse's wire to the positive of the IC pump
6. Ground the IC pump to anywhere you'd like
7. Insert original fuse into the add-a-fuse
8. Turn Key into on position. You should hear you fuel pump(maybe). You will defiantly be able to hear the IC pump(may have to put ear near it).
9. Enjoy you're automatically turning on IC pump
If you need a write-up on how to do it via a switch then you need to stop modifying your car....
Old Nov 9, 2012 | 05:45 PM
nhanson's Avatar
Good directions.
The whole S/C installation is pretty damn easy just time consuming.
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
