2.2 supercharge question
Old Jul 3, 2011 | 07:34 PM
07cobalt_LT's Avatar
Im running a 2.2 supercharged.
Im using the factory 2.2 map sensor mounted in the intake manifold where the LSJ second map sensor would install.
My question is, if i moved my factory map sensor to the supercharger location where the first lsj map sensor would install would that cause any issues? affect my tune?
The reason im wondering this is because i would like to install an iat gauge sensor in the intake manifold where my current map sensor is located.
Old Jul 3, 2011 | 07:48 PM
heathkidder's Avatar
iv seen the map sensor in both spots but i believe there is rewiring you have to do im not sure on that but i no its been both spots
Old Jul 3, 2011 | 07:49 PM
i have enough slack in my harness to move it over. so im guessing should be much of an issue then?
Old Jul 3, 2011 | 07:51 PM
why would u even want to move it is my ?
Old Jul 3, 2011 | 08:21 PM
i wanna run an iat sensor in its location so i can read iat 2 temps
Old Jul 4, 2011 | 03:42 AM
IonNinja's Avatar
so you're wanting to run the LSJ map sensor instead of the L61 one?
Old Jul 4, 2011 | 07:51 AM
no im going to run my stock one in the supercharger
and a stand alone IAT gauge in the intake manifold to monitor my IAT2 temps
Old Jul 4, 2011 | 08:42 AM
1LowLS's Avatar
you can definately run it there but you would need to be retuned as that port is purely vacuum and reads no boost,so your map you be reading nothing but vacuum.
Old Jul 4, 2011 | 11:27 AM
IonNinja's Avatar
Where are you getting this from?
Old Jul 4, 2011 | 05:07 PM
PLX Devices
brandon04
Oct 21, 2015 07:04 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
z28addiction
Sep 28, 2015 12:03 AM
