2.4 crank in a 2.2?
2.4 crank in a 2.2?
As some of you guys may already know, I pretty much live for American V8 power and engine building is a hobby that runs in my blood. Well with older V8s one of the easiest ways to pick up some power is to pull a crank out of a larger displacement motor. I know the bore is larger on the 2.4 as well, but will the 98mm crank fit?
Because switching the crank ups the displacement without having to get a whole new motor, that is the point of crank swapping. To put it in terms of a V8s: what I proposed is equivalent to putting a 400 crank in a 350 to create a 383, but you told instead of buying a crank (around $300) to go out and buy the entire 400 motor (a couple grand). So to answer why I would do all that: because it is a cheap way to up displacement without going out and spending big cash on a whole new block.
Thanks, I was worried about that. I will check into a bit more when I get the chance.
This is not new idea, and in the 4-cylinder arena, it's just not as feasible as with V-8's. The amount of work necessary to get it operate outweighs the costs. It is in fact cheaper to just trade the car.
