2.4 crank in a 2.2?
Old Apr 17, 2008 | 11:32 AM
Enzo_Guy's Avatar
2.4 crank in a 2.2?
As some of you guys may already know, I pretty much live for American V8 power and engine building is a hobby that runs in my blood. Well with older V8s one of the easiest ways to pick up some power is to pull a crank out of a larger displacement motor. I know the bore is larger on the 2.4 as well, but will the 98mm crank fit?
Old Apr 17, 2008 | 11:33 AM
omgshesaboy's Avatar
i did not know that about you
Old Apr 17, 2008 | 11:36 AM
YellowLT's Avatar
I've looked into this befoore but couldn't find anything conclusive. I think the bearings/caps and seals are larger on the 2.4 though.
orngebalt's Avatar
why do all that. when you can just swap a 2.2 with a 2.4
Old Apr 17, 2008 | 11:38 AM
LE5CAV's Avatar
They Have Different Crank Triggers, They Will Swap But Your Ecm Will Not Support It
Old Apr 17, 2008 | 02:31 PM
Enzo_Guy's Avatar
Because switching the crank ups the displacement without having to get a whole new motor, that is the point of crank swapping. To put it in terms of a V8s: what I proposed is equivalent to putting a 400 crank in a 350 to create a 383, but you told instead of buying a crank (around $300) to go out and buy the entire 400 motor (a couple grand). So to answer why I would do all that: because it is a cheap way to up displacement without going out and spending big cash on a whole new block.
Thanks, I was worried about that. I will check into a bit more when I get the chance.
Old Apr 17, 2008 | 02:33 PM
Jn2's Avatar
Jn2
keep us updated, it would be nice to see a stroker 2.2...i mean 2.4
Old Apr 17, 2008 | 04:59 PM
ChevyRockstar's Avatar
I like enzo thoughs
EX: 350 block + 400 crank =383 stroker(my camaro engine)
maybe be the same for 2.2 block with 2.4 crank, if you can fix the ECU to work properly
Old Apr 17, 2008 | 05:39 PM
Halfcent's Avatar
I'm old school
This is not new idea, and in the 4-cylinder arena, it's just not as feasible as with V-8's. The amount of work necessary to get it operate outweighs the costs. It is in fact cheaper to just trade the car.
Old Apr 17, 2008 | 09:39 PM
Enzo_Guy's Avatar
I think it would be a 2.3L, it comes out to like 2.97-something liters.
Stuff
Oct 1, 2015 05:47 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
cw383
Sep 30, 2015 12:41 AM
