2.4 intake manifold problem
Old Mar 8, 2009 | 08:15 PM
dsmlaser90's Avatar
put everything in correctly..but when you fire it up for the first 10 seconds its fine..then the engine just boggs down...im thinking this might be that the map sensor needs pressed in more..any ideas?
Old Mar 8, 2009 | 09:51 PM
NWAE Cobalt's Avatar
2.2l tb or 2.4l tb ???
Old Mar 8, 2009 | 10:01 PM
MP Cobalt's Avatar
LoL If I knew I'd help you bro, but I have no clue. Tom any ideas?
Old Mar 8, 2009 | 10:05 PM
SportRedLT's Avatar
hmmmm i just installed mine yesterday and didnt have that but weirdd this might sound crazy but maybe do it again? take it back apart quick(doesnt take too long) and reassemble making sure you did everything, and did you make sure the battery was unplugged when you did it? i forget where i read it someone correct me if i am wrong but i thought you need to not only for safety but so the air flow sensors could readjust or something?
Old Mar 8, 2009 | 10:07 PM
MP Cobalt's Avatar
It's a 2.2 TB
Old Mar 8, 2009 | 10:08 PM
if he bought an intake mani with tb on it then he is having prob and in need of a tune, if he bought the adapter plate and using his 2.2 l throttle body then ....i would start with reseting the maf
Old Mar 8, 2009 | 10:15 PM
MP Cobalt's Avatar
Yeah possibly, but I never heard of that.
Old Mar 8, 2009 | 10:50 PM
Nato09's Avatar
did you unplug the battery when you installed it?
Old Mar 8, 2009 | 10:52 PM
ilovecars's Avatar
yea i would say unplug battery then retry
Old Mar 8, 2009 | 11:39 PM
Jn2's Avatar
Jn2
check for vacuum leaks
Old Mar 9, 2009 | 12:08 AM
lwpmoon's Avatar
When I installed mine I replaced the break booster hose. In the process I damaged the seal were the hose connects to the master cylinder. That caused the vacume leak for me. But nothing a little super glue couldn't fix.
Old Mar 9, 2009 | 01:39 AM
dsmlaser90's Avatar
thanks for all the advice guys..and no i didnt have the battery off...also after doing this header/dp when it first starts up and i drive it its like it wants to go into limp mode for a few seconds then its ok..should i just unplug the battery and reset the ecu
Old Mar 9, 2009 | 10:30 AM
SportRedLT's Avatar
diconnect the battery for a few seconds, then when you start it let it run idle for a few minutes before you drive it to adjust, doesnt have to be too long.....when i did mine i started it, ran inside and showered and stuff real quick then came back out for the test drive(and what a nice test drive that was)
Old Mar 9, 2009 | 12:08 PM
dsmlaser90's Avatar
would u need to disconnect for the header/dp too..kinda weird how it always does it now when i drive it
Old Mar 9, 2009 | 12:58 PM
SportRedLT's Avatar
hmmmm idkk possibly with the 02 sensors on there id suggest doing it anyways just because
Old Mar 9, 2009 | 02:33 PM
MP Cobalt's Avatar
I never had that problem with the headers. make sure you got no leaks and I'd reset the ecu.
DarrenGC
Dec 24, 2021 01:55 PM
patooyee
Oct 15, 2015 05:11 PM
Sep 27, 2015 08:53 PM
