2.4 manifold crank seal
Old Apr 24, 2010 | 09:51 AM
07cobalt_LT's Avatar
so the middle seal that blocks off the opening when you do a 2.4 manifold swap to a 2.2 what does that seal do? i know it blocks if off but what if you dont have it?
Old Apr 24, 2010 | 03:45 PM
flyy's Avatar
I was wondering the same thing about 3 weeks ago when i received my 2.4l IM swap. The kit didn't come with the crank seal so I had to buy one from gmparts website. I'm not sure exactly what it does but I do know you can't block it off because it is some sort of a vacuum seal. Basically I tried it without the seal to see how it would effect my car and my car totally ran like ****. It acted just as if a vacuum hose was unhooked. So if you're planning on getting the kit or already have it plan on also purchasing the crank seal as well as it doesn't come with the zzp kit only the CED kit (don't quote me on CED but it's in their picture)
Old Apr 24, 2010 | 08:46 PM
Jn2's Avatar
Jn2
when i did the 2.4 manifold swap i just swapped over all my gaskets from the old manifold
Old Apr 24, 2010 | 10:44 PM
flyy's Avatar
yeah well i had to order the gasket for the center my old manifold didn't have the right gasket but then again my is a 2008 so the manifolds are different.
Old Apr 29, 2010 | 11:25 AM
ml2242's Avatar
You need all gaskets they are there for a reason.
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
Trav3480
Sep 28, 2015 02:46 PM
