2.4 SS cams in a 2.2
I was just wondering if anyone has tried the 2.4 SS cams in a 2.2 and if so did you need a tune and did you gain any power? I am thinking about doing this mod in the future and am not sure if it's worth the time and the money.
I know I wasn't sure if they would work but I know that I would be able to get factory SS cams cheaper than comp cams and I'm sure you will need a tune with those cams also I just figured that you may not need a tune with the factory SS cams because there not as aggressive.
yea go with the aftermarket cams you will get more power out of it because it is design for the 2.2L motor and once you do that you can get it tuned by vinced from trifecta cuz he does great work.
You don't need to take the head or valves off. If you take the valve cover off you have access to them.
