2.4 tb
Old Oct 10, 2011 | 10:51 AM
cobraceralt's Avatar
2.4 tb
I want to put on the 2.4 tb to complete my full bolt ons but i cant remember if the 6 pin or 8 pin is easier. I tried searching and found nothing
Old Oct 10, 2011 | 11:06 AM
drumrush's Avatar
it depends, do you have an 8 pin or 6 pin yourself? go check. if theres 6 pins coming out of your tb then you want a 6 pin. if you have 8 wires, you want an 8 pin.
and keep in mind that you cant run the larger tb without a tune
Old Oct 10, 2011 | 09:41 PM
noorj's Avatar
False, you can run a larger throttle body without a tune. You could probably even run an lsj throttle body without a tune. But it does depends on if you have sai or not.
Old Oct 10, 2011 | 09:56 PM
drumrush's Avatar
i just got into a big ****** argument about this a few weeks ago. the only 2.2 that can run a larger tb without a tune is the LAP. the L61 needs a tune, or it will go into limp mode as soon as you start it
Old Oct 10, 2011 | 10:39 PM
I'm pretty sure 07+ is 6pin (at least mine is 6pin) and i know 06 is 8pin, unsure about
Old Oct 11, 2011 | 12:06 AM
night_throne's Avatar
BULLSHIT
ive had the lsj TB on for about a month now without a tune for it with np u only throw limp mode if u have to rewire to get the signals right and dont
Old Oct 11, 2011 | 06:45 AM
Originally Posted by night_throne
BULLSHIT
Do you have a wideband? (just wondering what the afr's are without a tune)
Old Oct 11, 2011 | 07:24 AM
nhanson's Avatar
pretty sure the scaler rating is gonna be fucked till you tuned (LSJ)
Old Oct 11, 2011 | 09:57 PM
well my car is currently in the shop getting a new motor under warrenty i was just wanting to get the TB in the mean time and i do have SAI if that makes a difference on getting a bigger throttle body?
Old Oct 11, 2011 | 10:02 PM
nhanson's Avatar
no it does not
Old Oct 12, 2011 | 02:23 AM
i couldnt tell u what my AFR were but vince did tell me today when he sent me the tune i was running a tad bit lean because of being able to take more air in
Old Oct 12, 2011 | 05:15 PM
huckernage's Avatar
he is right
it is possible getting 1400 idles
you can ride it but if you WOT, you ll get limp mode
Old Oct 12, 2011 | 07:57 PM
Originally Posted by huckernage
he is right
this is once again wrong just so u know unless my car is some freak of nature
Old Oct 12, 2011 | 08:09 PM
huckernage's Avatar
i ve reflashed over 8 car that add this on there 2.2.
every single one came back asking for a reflash
Old Oct 19, 2011 | 04:19 PM
boltedbalt's Avatar
OKay boys so whats the word here can it be done without a tune?
Old Oct 19, 2011 | 05:13 PM
i ran the lsj tb on my 2006 l61 np without a tune id say go for it if u go limp mode just switch back till u can get tuned
Old Oct 20, 2011 | 03:45 PM
Jesse's Avatar
How can you tell if your car goes into limp mode? I've never experienced it.
Old Oct 20, 2011 | 04:54 PM
oh you will know the engine will have 0 power the reduced engine power light will come on
Old Oct 20, 2011 | 05:19 PM
Jesse's Avatar
Thanks.
Old Oct 20, 2011 | 06:11 PM
boltedbalt's Avatar
anyone try this?
Old Oct 20, 2011 | 06:21 PM
anyone try this?
as i said above i ran the lsj throttle body untuned for over a month with no issues personally
red9
Oct 4, 2017 02:23 AM
Barkleyj605
Oct 24, 2015 12:07 AM
patooyee
Oct 15, 2015 05:11 PM
matthewwalsh1994@gma
Sep 10, 2015 10:48 AM
