2.4intake mani question
i noticed a difference...about 9-11hp increase...i didn't have to tune but it would help...and if you are using the stock air plenum air box setup then buy a k&n drop in filter to go along with it....it really only takes about 45 min to install....actually you could just get the manifold, the kit on CED is pretty much pointless, you don't need the adapter plate, all you need is an extension for the brake booster line (1/2" heater hose with couplers and hose clamps) and the PCV seal....don't even need the bolts....i have an 07 though so it may be different for later models....i'll post pics later on of the install....make sure though if you have the electronic TB that if you unplug it it will throw a P0122 and a P0223 code and will have to be cleared before you can actually drive the car...
P0122 - Pedal Position/Throttle Position Sensor Circuit B Low Input
P0223 - Pedal Position/Throttle Position Sensor Circuit B High Input
Meaning they aren't reading in the ECU and the DIC will show "Engine PWR Reduced"
as far as bolt torque specs just tighten them so they hold....the holes bottom out and if you apply to much pressure they will snap in half so a good snug down should be fine for the manifold and TB...
any more questions?
any more questions?
i have the 2.4manifold with the stock airbox and K&N drop in filter and the torque loss is slightly noticeable but not enough to regret buying it or want to swap back to the old manifold, i even dynoed after the manifold and its making power past 7000rpm where before it made power to about 6300rpm and start to fall off
We really need dyno number with the 2.4TB on there.
You say it throws those codes, but what if you unplug the battery before install? How can it throw those codes if it doesn't know you removed it.
any more questions?
any more questions?
To the OP whats up with all the threads asking old question. Just do a search and you'll find answer for a lot of your questions.
To the 2.4TB questions. Im already working on it. Currently working out the small issues but it works!
I am the pioneer!
Thats not true when I got my setup I tried doing it without the adapter plate and there was a very small leak to the very left of the throttlw body. The gasket was sticking out and would have possibly blown had i left it like that. it ould be just because I have an early 2005 model but either way it is needed.
any more questions?
any more questions?
I am the pioneer!
Thats not true when I got my setup I tried doing i without the adapter plate and there was a small leak to the very left of the throttlw body. The gasket was going to blow had i left it like that. it ould be just because I have an early 2005 model but either way it is needed.
as for the codes....the battery being unplugged will still throw those codes...(it did for me twice)...but luckily i had my scan tool on hand it fixed the problem easily...
Last edited by FacelessKhaos; May 10, 2008 at 03:23 PM. Reason: Automerged Doublepost
wow you guys must be doing somethin wrong mine never thru a code and i didn't seem to lose any torque. and you need to wait for the car to warm up and hit closed loop after installing the manifold so it doesn't throw a code.
^^Who? No one threw a code. The OP wanted to know if installing the 2.4 mani would throw a code and the discussion went to talk about something else.
So my question is what are you talking about?
pretty much you will only throw codes it you use the 2.4tb, not because it's bigger, but because the TPS is different and has different voltage values i do believe, but i could be wrong...but then again i can always go pull one off and try it....
P0122
P0223
both TPS sensor circuit B codes, one for the high input and one for the low input
but like i was saying...it probably was just rare anomaly with my car to throw those codes after i took off the TB and then ported/polished it....remember this is the electric throttle body on the 07 Cobalt's...not the cable style...static discharge, bad contact, dust, or something that could have gotten into the connector. I unplugged and then plugged it back in and cleared the codes and it hasn't thrown them again....
along with the codes the DIC showed "Engine PWR Reduced".....
so....that was i trying to say....and for those to be careful so it doesn't happen to anybody else...
no...i'm pretty sure it was my car throwing TPS codes.....
P0122
P0223
P0122
P0223
