2.4intake mani question
Old Aug 10, 2008 | 07:19 PM
  #51
CobaltLs_14's Avatar
Thats perfect guys thanks for the help...
I just cant wait to put it on now i think it'll help out a lot...
Old Aug 12, 2008 | 03:10 PM
  #52
burzumaske20's Avatar
that is why I am going to get the 2.4 intake manifold soon,it would have good gains with other mods.Right now I am in the process of finding the welder so I can get my brother to make me a custom 2.5 downpipe and put on that pacesetter header already.
Old Aug 14, 2008 | 09:54 PM
  #53
Just double checking...
I DONT need the TB adaptor since i have a 07 right?
I keep hearing different things i'm getting put on this weekend and need to know thanks...
Old Aug 14, 2008 | 10:05 PM
  #54
Spanky's Monkey's Avatar
07 does not need the adapter
Old Aug 16, 2008 | 10:42 PM
  #55
dragonkingg5's Avatar
so wheres the dynos?? i know a few ppl got this now so lets get some numbers up.
anyone with the 2.4 mani have the 2.4 throttle body??
how much more air does it bring it?
I still have the stock DP, will the engine be ok bring in alot more air and trying to push that air out with the stock dp?
some more questions
Old Aug 16, 2008 | 10:57 PM
  #56
Red07SSNA's Avatar
Dyno's are in other threads and on the CED website. This mod is now more than a year old!
Old Aug 17, 2008 | 12:24 AM
  #57
07's can't use the 2.4 tb cause it's a 8 pin and the 07's are 6 pin. yzrider found that out the hard way. i'm buying his 2.4 tb from him. on a side note we tested it on my car and the car ran fine on the first launch and hit limp mod like a brick wall on the second, lol.
Old Aug 17, 2008 | 09:26 AM
  #58
Red07SSNA's Avatar
My 07 2.4L TB is an 8-pin.
Old Aug 17, 2008 | 09:55 AM
  #59
MP Cobalt's Avatar
Well i own a 2.2l 06 all my mods are listed in my sig. Do you think the 2.4 mani of Crate engine will help me or just screw me with limp mod? i plan on getting comp. cams and the tune from Clear Imagae
Old Aug 17, 2008 | 11:10 AM
  #60
Red07SSNA's Avatar
If you install the 2.4 manifold (CED's kit includes the 2.2 throttle body adapter plate) you won't have a problem. You can't run the 2.4L throttle body on the 2.2 without tuning for it.
Old Aug 17, 2008 | 11:28 AM
  #61
theres no adapter so the 07s can use the 2.4 TB?
Old Aug 17, 2008 | 12:32 PM
  #62
Red07SSNA's Avatar
The adapter is used between the 2.4L manifold and the 2.2 TB to insure a good/long term seal. Some say the 07 2.2 TB doesn't need the adapter -- check yours closely after installation to insure the seal is good.
The 2.4L TB-to-manifold seal is physically larger then the 2.2L TB-to-manifold seal. The adapter plate makes it so the 2.4L TB-to-manifold seal works with the smaller 2.2 TB's base.
07 2.2L engine cannot use the 2.4L TB without a tune.
Old Aug 17, 2008 | 01:10 PM
  #63
El Mariachi's Avatar
I was informed by crates depot that tune is not nessesary for the 2.4 mani swap for the 2.2 ls model
Old Aug 17, 2008 | 04:11 PM
  #64
i worded that wrong red. theres a post above saying we have 6 pin TB and the 2.4 is 8 pin TB so we couldnt use it. im 07 btw.
is that true? thought 07s could use it. i got a trifecta tune but its not made for 2.4 TB, so if i got the TB, i would have to contact vince and have him retune me for the 2.4 TB then or the one i have good enough?
Thanks
Old Aug 17, 2008 | 04:56 PM
  #65
in my post i stated that the 2007 2.2 has a 6 pin connector the 2.4tb has an 8 pin connector therefore the 2.4 tb will not work in the 2007 2.2 under any circumstance. the 2006 2.2 has the 8 pin connector however it will need tuning to use the 2.4 tb.
i was talking about the 2007 2.2's having 6 pins. the 2007 2.2 cannot use the 2.4 tb period. it's just not an option at this point. sorry, if you got confused.
Last edited by Spanky's Monkey; Aug 17, 2008 at 04:56 PM. Reason: Automerged Doublepost
Old Aug 17, 2008 | 07:42 PM
  #66
Red07SSNA's Avatar
It's rather sad that it is so difficult to swap out the simplest parts!
Old Aug 18, 2008 | 11:52 PM
  #67
Got the 2.4 installed this past weekend and love the top end power its great for the free way but i do miss the low end power, i miss the initial burst...
Used to generate power 2800-3200
Now From 3500-4000
How do i get my low end back with out a tune or is there a tune for the 07 ecu yet?
Old Aug 19, 2008 | 12:00 AM
  #68
I believe if you go with the tune you can gain back that torque possible.I heard someone say before if you have a performance header on you will gain what you lost in torque with the 2.4 manifold.
Old Aug 19, 2008 | 12:03 AM
  #69
I have the SAI so that is kinda out of the question plus i'm from cali so yeah that says it all...
My mods are in my sig what should i do?
Old Aug 19, 2008 | 12:06 AM
  #70
ah **** that sucks then,well you will most likely have to get a trifecta tune then to make up for the lost torque but since you're going turbo hold off then for the tune
Old Aug 19, 2008 | 12:12 AM
  #71
Yeah Hahn Racing wont come out with that till the end of the year (so i've heard)...
Is there anything i can do to get more power? What other mods can i do?
Old Aug 19, 2008 | 12:32 AM
  #72
well you can go with slightly bigger injectors at least 34 pounds or 35 pounds but that requires a tune as well lol.Honestly though if you didn't have the SAI **** I would say the header and that will free up some hp for sure.You can start doing some motor work,cams,port and polish,pistons,valve springs,ect.I am waiting to get my cams until I get the supercharger,which I am going to go with the so call stage 3 cams.
Old Aug 19, 2008 | 12:37 AM
  #73
07blackg5's Avatar
Slobodan Milošević
lol people are flipping about the tune and limp mode because they dont know/realize that the throttle body and intake manifold are 2 different things
Old Aug 19, 2008 | 12:41 AM
  #74
Yeah thats what i was thinking... doing some internal work but yeah the SAI and living cali suck well i love cali its just the emissions that suck...
I thought 07 cams arent out yet due to the cam sensor?
Old Aug 19, 2008 | 12:42 AM
  #75
07blackg5's Avatar
Slobodan Milošević
someone with an 07 did it but it required a bit of trimming
