AC Delete on my 2.2 G5.
Old Jul 27, 2010 | 12:56 AM
EPro's Avatar
Symptoms:
-Car almost stalls when AC is turned on
-Recently, the car starts almost stalling when the vents are turned on (AC turned off)
-I can hear the AC Compressor making bearing noises while driving occasionally.
I don't have the money to get this fixed, and the AC in my Z28 works beautifully, I'm reading in other threads that I will lose my ability to defrost windows if I choose to remove the pump instead of fixing it, is this true or Internet blasphemy?
Also, I grabbed this picture from another thread.
Will I need a different accessory belt after I remove the AC? What's the best way to get rid of it?
Old Jul 27, 2010 | 10:19 AM
brandon11482's Avatar
You sure its not the pressure in the A/C lines being too high? (sometimes you can have excessive air in the lines) Which will make the compressor harder to turn & causing more "drag" than normal on the engine.. Might want to check that out.
Old Jul 27, 2010 | 11:37 AM
EPro's Avatar
Either way my compressor would be considered no good? there still is pressure in the lines, but the noise coming from the compressor just screams, "kill me"
Old Jul 27, 2010 | 11:57 AM
ItalianJoe1's Avatar
Best bet is to gut the compressor housing if you want to make it function like and idler.
Why not just unplug the compressor clutch wire so it doesn't engage?
Old Jul 27, 2010 | 11:59 AM
nhanson's Avatar
you might be able to defrost still but its going to take longer and might not even work
the compressor uses the A/C system to remove water from the air
and you might be stalling from a dirty TB
bykryder83's Avatar
Delete all of it if ur gonna do it, gm has a belt for just the crank,idler,and alt.....lmk if u need a part number
Old Jul 27, 2010 | 04:40 PM
EPro's Avatar
I'd like that if you could
Old Jul 27, 2010 | 04:42 PM
Maven's Avatar
defrost will still work, just wont be ass effective on fog when its hot out. will work fine in cool/cold weather
Supercharged06SS
Dec 11, 2022 04:47 PM
dennis69
Oct 20, 2015 07:39 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
ThoR294
Sep 28, 2015 05:31 PM
