Bad MAF?
Old Mar 18, 2010 | 03:08 PM
xxxxsh4d0wxxxx's Avatar
Bad MAF?
Unplugging the MAF while the car is running: Idle is the same
Unplugging the MAF while the car is off, and then starting the car: Idle is the same
Unplugging the MAF and driving it with it unplugged: Car runs the same.
I think I have a bad MAF, but my buddy says that even with the MAF out, the car will go off of base air/fuel maps and it will won't effect idle.
My idle is fairly choppy and it just doesn't sound right.
Fuel filter is new
Spark plugs are new
TB is clean
Coil packs are good (unplugged each one while the car was running, idle got worse for all 4 cylinders.
What do you guys think?
Old Mar 18, 2010 | 03:46 PM
TheSauce's Avatar
Did the idle problem start after the new spark plugs went in? Are you getting any codes or check engine light? Do you have a Multimeter? If so, set it to DC volts and check the connector at the MAF for power with the key on.
Old Mar 18, 2010 | 04:12 PM
Yeah, as of today I have some code for the MAF and some code for IAT.
MadBrad's Avatar
How did you clean your TB? Improper cleaning can mess with the position of the blade.
Old Mar 18, 2010 | 04:16 PM
TB cleaner. Manually moved the butterfly and wiped it with a shop rag.
Old Mar 18, 2010 | 04:20 PM
MadBrad's Avatar
Not recommend to use TB cleaner and move the blade manually. I did that and it cause me to idle weird. Picked up a local TB and everything was fine.
Old Mar 18, 2010 | 04:25 PM
TheSauce's Avatar
Well if the light/code came on today, its probably because you unplugged it with the car running. It doesn't sound like the problem to me. That code might reset itself if the MAF is connected for a few run cycles. Were the spark plugs properly gapped before install?
Old Mar 18, 2010 | 05:32 PM
06_ion2's Avatar
TPS can wear out in certain spots, on the peddle and TB at any givven time.
Old Mar 19, 2010 | 12:37 AM
Yes, they are the stock AC Delco plugs for the vehicle, I got them at NAPA, as I have a friend who works there, got them at discount price. They come pre-gapped. I know this is not always trustable, so yes, I did check them. From memory, I believe they were .043
****.. See I knew that wasn't a good idea, but I didn't see how it would harm it as long as I wasn't using a lot of force. Whoops! I pretty much narrowed it down to the MAF and TB. I guess my hunch was right.
Throttle Position Sensor?
Old Mar 19, 2010 | 11:31 PM
Do_WorkSS's Avatar
**** i was under the impression that a car wont even start with the MAF unplugged. i learned something new today. and as far as cleaning, you deserve a swift kick in the ***** if you use TB cleaner on it. take yourself to Autozone and buy a bottle of MAF cleaner. its $3-$5 and works great.
Old Mar 20, 2010 | 02:18 AM
I used TB cleaner on the TB, and MAF cleaner on the MAF..
Oct 13, 2015 09:32 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Iceberg
Sep 29, 2015 12:33 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
