Balt might need new engine need help!
Some background 2006 cobalt base model L61 engine automatic. Nothing fancy can't complain got the car for $500 because the previous owner didn't know what was wrong with it was only bad spark plugs. Travel 9 months later odd knocking noise starts but only once in a while, oil is good just changed it, does over heat a little cool was low, almost always needing to be added every couple weeks. Thought it was a rod knock but after talking it over with a couple certified mechanics ( friends as well ). Ruled it out because when idling sounds perfectly normal, not even a chain slap. So was saving up money and waiting for one last paycheck this upcoming friday to get it looked at and taken care of.
Coming home last night usual knocking noise starts up going up a rather large bridge, which is normal but after getting to the top and coasting down the noise still remains and gets louder. Get to my cousins house check the oil ( even though i just topped it off 2 days prior ) showing 4 quarts low roughly, checked the pulley system and belt and there is oil everywhere, looked under the the car and it looks like oil was coming out at a decent rate enough to coat under the passenger side of the car. Friend tells me it sounds like a crank bearing gave out. Not sure still turns over but the noise is enough to make me cry. Love this car and hate to see it go to the scrap yard because of a junk engine, ( had a 2004 cavalier lock up because of the timing chain tensioner ).
Also have a possible engine to replace the bad one for $600 and transmission for $250 same year cobalt it is from 101k mileage. Input would help amazingly.
As long as the *new* engine doesn't have a million miles, i'd say do it. What do you have to lose on a $500 car? That new engine (assuming in good health) will last you many more years, once again, assuming that you'll take care of it.
Oil leak could be too many things. I would have someone start it and see if you can spot the leak. Maybe try cleaning it off before. Make sure it's got oil in it though lol.
Does it smoke?
Does it smoke?
Does it smoke?
Does it smoke?
I do appreciate the info folks.
patooyee
Oct 1, 2015 01:07 PM
roth
Sep 26, 2015 12:16 PM
