bluestreaks sc build be prepared for some Q&A
Old Jul 20, 2012 | 12:35 AM
bluebalt07's Avatar
Try the way I told you about to compress the tensioner, but also loosen the bolts on the sc and tilt it forward. That should give you a little more room to play with, but it is definitely a pain. Then once the belt is on just push the sc back down onto the manifold and tighten the bolts.
Old Jul 20, 2012 | 01:58 AM
bluestreaks's Avatar
hey bluebalt, that actually worked the best, i got it on. now time to flash trifecta
Old Jul 20, 2012 | 02:08 AM
ryman416's Avatar
and ur done??
Old Jul 20, 2012 | 02:32 AM
Reklo87's Avatar
I hope all goes well for you bluestreaks. I want to put a SC on mine sometime soon.
yea pretty much done, just gotta flash it in the morning, sinse its starting to rain .
Old Jul 20, 2012 | 02:34 AM
thanks recklo, just make sure you have 3 bolts on the passenger side mount/lift hook. if you have 2 its a pain in the ass. and your gonna need a saw zaw
Old Jul 20, 2012 | 02:39 AM
and my dipstick wont go back in... probably gotta bend the **** out of it.
Old Jul 20, 2012 | 02:40 AM
Reklo87's Avatar
Dang rain...
Dang dipstick...
Old Jul 20, 2012 | 08:12 AM
ryman416's Avatar
pics or it didnt happen
Old Jul 20, 2012 | 12:48 PM
Lol ok we'll be posting pics up when the rain stops
Old Jul 20, 2012 | 11:42 PM
  #36
Reklo87's Avatar
I will rememeber that... Thanks.
Old Jul 21, 2012 | 02:37 AM
  #37
car is not starting.. it cranks but wont turn over
Old Jul 21, 2012 | 10:17 AM
  #38
bluebalt07's Avatar
Probably something not plugged in. Did you do any rewiring like for the throttle body, MAP sensor, MAF sensor? If not, check the fuses.
Old Jul 21, 2012 | 12:34 PM
  #39
lol yea i forgot that i had unplugged the fuel pump fuse, i plugged it back in. and ran it with out the tune, of course i had rough idle and what not, so i flashed it using trifecta. now the car wont stay on, it starts then turns off.
Old Jul 21, 2012 | 12:59 PM
  #40
bluebalt07's Avatar
Maybe try to keep it running by feathering the gas a little. Do the rpms like bounce at all before it dies?
Old Jul 21, 2012 | 01:10 PM
  #41
before i flashed it, i started the car up and the idle bounce up and down, it might have something to do with the tune that was sent to me,
Old Jul 21, 2012 | 08:21 PM
  #42
not even rain can stop me!!!! Name:  IMG_20120720_180458.jpg
had to saw zaw the lift hook/motor mount and move the bolt more to the middle Name:  IMG_20120720_180529.jpg
Old Jul 21, 2012 | 11:08 PM
  #43
ryman416's Avatar
nice pics dooood. you figure the problem or problems out yet?
Old Jul 21, 2012 | 11:50 PM
  #44
nope, not yet. i got some tunning issues and trfecta is closed till tuesday, so im **** out of luck till then
Old Jul 22, 2012 | 01:46 AM
  #45
IonNinja's Avatar
so apparently the motor mount or lift hook on the 05-06 cobalt are different from the 07+ ..damn it.
Yep hacked the **** out of mine to get it to fit with the LSJ tensioner initially but then I switched to the new style motor mount
Old Jul 22, 2012 | 10:08 AM
  #46
ryman416's Avatar
damn man that sucks. keep us posted on what happens
Old Jul 22, 2012 | 12:59 PM
  #47
Yea I saw zaw the motor mount and drilled a new hole for the other bolt
Old Jul 24, 2012 | 11:37 PM
  #48
Reklo87's Avatar
You get the balt tuned yet? I am interested in hearing how it turned out for you.
Old Aug 2, 2012 | 01:22 AM
  #49
this is my apology to vince, it was not vince that couldnt fix what my problem was, i guess he did all he could have done from being far. he told me that i had a jumpy throttle body, so i went and got 2 new throttle body just incase. and bamm.. idle issue at normal, small leak between the supercharger and the manifold, but will take care of that with an outside pvc couplings... sooo.. as soon as i get this vacumm leak all settle, the balt will be back on the road.
Old Aug 2, 2012 | 01:24 AM
  #50
ryman416's Avatar
so... youre following through with it after all? awesome! give us some pics!
