bluestreaks sc build be prepared for some Q&A
yea i went back to stock, then put a for sale thread up, then my girlfriend decidec to give it another chance while we wait to see if anyone was interested.. so if it didnt work this time, stock it was.. but this time it all went alot better..
Yea definitely. Hey not sure if your interested but a tuner from MA is gonna come down end of August/early September to tune a bunch of us. Not sure if you want to get street tuned and ditch the trifecta tune, but if not come to hang out.
https://www.cobaltss.net/forums/nort...eet-up-283846/
I'm pretty sure you are supposed to lube them up with some oil, that's what I did to mine. This way they slide in easy and don't get pinched or distorted and create a vac leak. Try re-installing them with some lube. If that doesn't work i'd get some new orings, but I'm pretty sure if you lube them up and reinstall it will solve your problem, that is if the vac leak is at the injectors. You sure it's there?
ok so it wasnt the fuel injectors, its coming from where the supercharger meets the manifold, its a small rubber gasket.. does anyone have the part number for that rubber gasket?
hey man how were you able to find out where the leak was coming from? I have a leak on my car and dont know where its coming from but it makes my car rev n such at idle and has died twice after a pull. only when the ac is off though.
keep your car running, and listen for a hissing soud, that hissing soud is a vacuum leak.. squeeze any sorounding tubes and if you can hear the hissing sound change then there you go...
