View Poll Results: whats the best cam for a fully bolted and tuned 2.2 na?
Stock
2.78%
gmpp performance
8.33%
comp cams stg 1
25.00%
comp cams stg 2
19
52.78%
comp cams stg 3
11.11%
Voters: 36. You may not vote on this poll
cam poll!
cam poll!
who has the best cams for a bolted 2.2
i want to buy a set so maybe everyone can help.... maybe
I don't think anyone here has anything above comp stage 2..may be wrong though.
The stage three grind is designed for a higher rpm band so, I guess if you can make power ((safely)) up near 8k they're the best.. If not you might wanna look at 2 or 1. I'm not sure on this though, from what I'veread this is my guess.
ëţáčňĺëč ćĺíńęčő ôîđě
Ńîçäŕë ňĺěó äë˙ ňîăî ÷ňî áű óçíŕňü ěíĺíčĺ îńňŕëüíűő ó÷ŕńňíčęîâ ôîđóěŕ.
Ńĺé÷ŕń ëĺňî, ćŕđŕ, âńĺ ńňŕđŕţňń˙ íŕäĺňü íŕ ńĺá˙ ęŕę ěîćíî ěĺíüřĺ îäĺćäű. Ćĺíńęčĺ ôîđěű ńňŕíîâ˙ňń˙ áîëĺĺ çŕňî÷ĺíű č ôčăóđčńňű. Číîăäŕ äŕćĺ çŕăë˙äűâŕĺřüń˙ â ńëĺä čäóůĺé ćĺíůčíĺ ÷ňî áű îöĺíčňü ĺĺ çŕä. Íĺęîňîđűĺ ďîďęč ňŕę ďđčň˙ăčâŕţň ňĺá˙ ďîňđîăŕňü ńĺá˙, ÷ňî ĺëĺ ńäĺđćčâŕĺřüń˙ ÷ňî áű íĺ ńäĺëŕňü ýňîăî. Ŕ ëčíčč ňđóńčęîâ ďîä ňîíęčě ńŕđŕôŕíîě ňŕę çŕâîä˙ň ÷ňî âńĺ óćĺ äŕćĺ íĺóäîáíî ńňŕíîâčňüń˙ ňŕę äîëăî ńěîňđĺňü.
Íî âîň őîňĺëîńü áű óçíŕňü ęňî íŕ ÷ňî ńěîňđčň â ďĺđâóţ î÷ĺđĺäü. Íŕ ăđóäü, ëčöî, ďîďęó, ňŕëčţ čëč ÷ňî-ňî äđóăîĺ?
Ěíĺ áîëüřĺ íđŕâ˙ňń˙ ćĺíńęčĺ ďîďęč. Ó ęîăî-ňî ýňî çŕäíčöű čëč ďđîńňî ćîďű.
 číňĺđíĺňĺ ńĺé÷ŕń ňŕę ěíîăî đŕçëč÷íűő đĺńóđńîâ ń řčęŕđíűěč ďîďęŕěč, íî áîëüřčíńňâî ńîäĺđćŕň ďîđíî ěŕňĺđčŕëű, ÷ňî íĺ î÷ĺíü đŕäóĺň. Ěîćĺň ęňî íčáóäü çíŕĺň ďđčëč÷íűĺ ńŕéňű?
Íŕďđčěĺđ ó ěĺí˙ ĺńňü ďŕđî÷ęŕ: çŕäíčöű íĺň, popsik.su, pyataya.com
just bc HE can deal with it as a DD doesnt mean everyone can thats why, not a lot of poeple could deal with mine as a DD, you need to know ur comfort zone, if having a car that vibs alot when ur at a red light is a issue, than get stgI, if you dont mind driving something uncomtable, than go stgII, stageIII is more for a track car, i doubt u want those...ur gunna need a engine build to handle the power band range they would put u in...balance shaft delete, valve springs, a crank pulley to handle a 8k rev...not entirely a engine build, but ur gunna be taking the engine out to get that delet kit installed...from what ive heard working on it still on a car is a bitch
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
