View Poll Results: whats the best cam for a fully bolted and tuned 2.2 na?
Stock
2.78%
gmpp performance
8.33%
comp cams stg 1
25.00%
comp cams stg 2
19
52.78%
comp cams stg 3
11.11%
Voters: 36. You may not vote on this poll
cam poll!
Old Jun 16, 2009 | 10:57 PM
08CPE?SS's Avatar
cam poll!
who has the best cams for a bolted 2.2
i want to buy a set so maybe everyone can help.... maybe
Old Jun 17, 2009 | 12:27 AM
Mr.N00bLaR's Avatar
Hmm best? What...?
I don't think anyone here has anything above comp stage 2..may be wrong though.
The stage three grind is designed for a higher rpm band so, I guess if you can make power ((safely)) up near 8k they're the best.. If not you might wanna look at 2 or 1. I'm not sure on this though, from what I'veread this is my guess.
Old Jun 17, 2009 | 12:47 AM
NWAE Cobalt's Avatar
depends on what your looking for. do you want a car that is more track then street? or one that does decent but is still 100% street and comfort friendly??
Old Jun 17, 2009 | 09:15 AM
popsikmopsika's Avatar
ëţáčňĺëč ćĺíńęčő ôîđě
Ńîçäŕë ňĺěó äë˙ ňîăî ÷ňî áű óçíŕňü ěíĺíčĺ îńňŕëüíűő ó÷ŕńňíčęîâ ôîđóěŕ.
Ńĺé÷ŕń ëĺňî, ćŕđŕ, âńĺ ńňŕđŕţňń˙ íŕäĺňü íŕ ńĺá˙ ęŕę ěîćíî ěĺíüřĺ îäĺćäű. Ćĺíńęčĺ ôîđěű ńňŕíîâ˙ňń˙ áîëĺĺ çŕňî÷ĺíű č ôčăóđčńňű. Číîăäŕ äŕćĺ çŕăë˙äűâŕĺřüń˙ â ńëĺä čäóůĺé ćĺíůčíĺ ÷ňî áű îöĺíčňü ĺĺ çŕä. Íĺęîňîđűĺ ďîďęč ňŕę ďđčň˙ăčâŕţň ňĺá˙ ďîňđîăŕňü ńĺá˙, ÷ňî ĺëĺ ńäĺđćčâŕĺřüń˙ ÷ňî áű íĺ ńäĺëŕňü ýňîăî. Ŕ ëčíčč ňđóńčęîâ ďîä ňîíęčě ńŕđŕôŕíîě ňŕę çŕâîä˙ň ÷ňî âńĺ óćĺ äŕćĺ íĺóäîáíî ńňŕíîâčňüń˙ ňŕę äîëăî ńěîňđĺňü.
Íî âîň őîňĺëîńü áű óçíŕňü ęňî íŕ ÷ňî ńěîňđčň â ďĺđâóţ î÷ĺđĺäü. Íŕ ăđóäü, ëčöî, ďîďęó, ňŕëčţ čëč ÷ňî-ňî äđóăîĺ?
Ěíĺ áîëüřĺ íđŕâ˙ňń˙ ćĺíńęčĺ ďîďęč. Ó ęîăî-ňî ýňî çŕäíčöű čëč ďđîńňî ćîďű.
 číňĺđíĺňĺ ńĺé÷ŕń ňŕę ěíîăî đŕçëč÷íűő đĺńóđńîâ ń řčęŕđíűěč ďîďęŕěč, íî áîëüřčíńňâî ńîäĺđćŕň ďîđíî ěŕňĺđčŕëű, ÷ňî íĺ î÷ĺíü đŕäóĺň. Ěîćĺň ęňî íčáóäü çíŕĺň ďđčëč÷íűĺ ńŕéňű?
Íŕďđčěĺđ ó ěĺí˙ ĺńňü ďŕđî÷ęŕ: çŕäíčöű íĺň, popsik.su, pyataya.com
Old Jun 17, 2009 | 09:19 AM
PSHHH's Avatar
what that guy said ^^
Old Jun 17, 2009 | 09:21 AM
BlackCobalt707's Avatar
what **** did he say? is that seriously russian?
Old Jun 17, 2009 | 01:48 PM
08CPE?SS's Avatar
ok well than answer it if you had the cash which one would you buy as a suped up daily driver
Old Jun 17, 2009 | 01:59 PM
alanoo's Avatar
It lacks an "other" choice
Old Jun 17, 2009 | 02:00 PM
stage 1
Old Jun 17, 2009 | 02:14 PM
08CPE?SS's Avatar
a poll with 5 choices lacks an other? the point is if you were to buy cams which one and possibly why. i left an other option for those who are against cams .
Old Jun 17, 2009 | 02:36 PM
alanoo's Avatar
Indeed, if by "bolted" it means no upgraded springs, that leaves you only two choices in fact
Old Jun 17, 2009 | 04:13 PM
randizzle's Avatar
Old Jun 18, 2009 | 08:58 PM
Mr.N00bLaR's Avatar
Originally Posted by NWAE Cobalt
stage 1
Why do you say stage one? You have stage two right? I remember you had some installation woes with the cams but don't you use your cobalt as a DD?
Old Jun 20, 2009 | 12:34 AM
BLKLS's Avatar
^x2?
I've been thinking about stage 2. Why do you say stage 1?
Old Jun 20, 2009 | 05:53 AM
Jn2's Avatar
Jn2
just bc HE can deal with it as a DD doesnt mean everyone can thats why, not a lot of poeple could deal with mine as a DD, you need to know ur comfort zone, if having a car that vibs alot when ur at a red light is a issue, than get stgI, if you dont mind driving something uncomtable, than go stgII, stageIII is more for a track car, i doubt u want those...ur gunna need a engine build to handle the power band range they would put u in...balance shaft delete, valve springs, a crank pulley to handle a 8k rev...not entirely a engine build, but ur gunna be taking the engine out to get that delet kit installed...from what ive heard working on it still on a car is a bitch
Old Jun 20, 2009 | 12:17 PM
BLKLS's Avatar
Word
Old Jun 20, 2009 | 01:16 PM
HyperMuffin's Avatar
Stage 4 are better.
Old Jun 20, 2009 | 01:22 PM
dman090's Avatar
if im not wrong, dont you need a special set of cams for an 07+ cobalt?
Old Jun 20, 2009 | 01:49 PM
08CPE?SS's Avatar
u just need a cam shaft position sensor on the intake cam, it can be tapped on
Sl0wbaltSS
Nov 21, 2018 11:11 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
