cams for an 07
cams for an 07
Does anyone know of any cams for an 07 lt. As far as I understand there are none because of the cam sensor. Will the ones from gm work pn 88958698. I just want a mild cam that does not require a retune.
www.turbotechracing.com
they have stage1 cams your can order off there page that do not require a tune..
however i have heard sct is within a month or 2 to realeasing there tuning solution so im kind of waiting to see what happens with that. because my plans for the car are going boosted i would like to get a different grind then the stage 1 ideally, but i guess well just have to wait and seee
Merged duplicate.
You are correct. The 2007 L61 has a completely different exhaust cam, and none of the previous L61 designs will work with it. To the best of my knowledge, nobody makes a set. And if I had to guess, nobody will now that the Ecotec line has expanded to higher performance models.
But you are still looking at $700 for 2 hp, does it sound worth it.
My opinion is hell no. You can get much better bang for the buck by just adding bolt ons.
Honestly, if you're going to go through the trouble of doing cam swap(s) you're gonna want it to make a big difference. I say this having done cam swap before (though it wa more difficult having been on a pushrod motor and half the motor is stuffed under the dash on the freakin thing). Before I got the camaro tuned it still ran fine, a little lean up top and stalled about once a week at a stoplight (which considering how many stoplights a day i sat at that's really good) but ran nicely and loped like a monster. My advice, if you're swapping cam(s), think big
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Sign_Something
13
Sep 26, 2015 11:44 AM
